Silicone Spray
Submitted: Sunday, May 27, 2007 at 14:45
Hairy
Gday,
Im just about to give my car (petrol 80 series) a
well deserved under bonet wash.
I was going to hit it with a can of degreaser, soapy water and then hose it off.
I was thinking of useing silicone spray on all the electrical bits after electrical cleaner (Contact Ol).
Do others use silicone spray?
Are there any reasons why I shouldnt use silicon spray?
Thanks in advance.
Reply By: Member - Phil G (SA) - Sunday, May 27, 2007 at 15:09
I rarely wash the motor, and don't use degreaser, because it may wash the grease out of factory connectors. I just wipe the motor or a quick hose with water at the happy wash. Only reason against silicone spray is that it will attract the next layer of dirt.
242694
Follow Up By: Hairy - Sunday, May 27, 2007 at 15:25
Gday Phil,
Thanks mate but ive got oil and bleep thats going to need degreaser. Ill just take it easy.
503685
Follow Up By: Member - Phil G (SA) - Sunday, May 27, 2007 at 15:31
Gday Hairy,
Yeah, I know what you mean.
I feel sorry for the people who get a free engine degrease with every service at the dealer - must have their fair share of electrical probs in the long run.
503686
Follow Up By: Member - Jiarna (NT) - Sunday, May 27, 2007 at 17:43
Hi Hairy
I agree. Just degreased the engine on the Falcon before hitting the road to
Adelaide, and it is running like a Nissan LOL. Hopefully it will settle down as the electrics dry out, and go back to running on 6 cyl instead of the current 4.
503711
Reply By: DIO - Sunday, May 27, 2007 at 18:39
How you apply the degreser (pressure/volume etc) will have a big influence on the possibility of causing problems. Furthermore, water, applied directly to electrical components, seals, hoses, belts, bearings, connectors, etc at high pressure is almost guaranteed to cause major damage. If you must hose the engine, use very low pressure spray (NOT jet) and avoid prolonged application to any likely vulnerable components.
242723
Reply By: Member - Pesty (SA) - Sunday, May 27, 2007 at 19:23
I spray on a bit of diesel/petrol mix to bad areas, then a good dose of truck wash, let soak for a while then plain water pressure cleaner, works
well, and i do it fairly regular so it doesnt get to bad.
Cant see any reason silicon spray wont work, its good for most things.
Cheers pesty
242736
Reply By: Hairy - Sunday, May 27, 2007 at 19:26
Cheers All,
Yeh , I done it.
No problems starting it .
Ill let you know how it comes up after Finke, interesting to see how bad the dust sticks.
Thanks.
242740
Reply By: Auntie - Sunday, May 27, 2007 at 19:34
Plastic bags over the delicate bits, no high pressure, just a hand wash, finish with a good squirt of WD 40. Comes up a treat.
242742
