UHF Radio in a BA Falcon
Submitted: Saturday, May 19, 2007 at 20:22
Member - Steven H (ACT)
I have decided to fit a
UHF radio into the BA Falcon so when l am towing the camper I can keep an ear on the
UHF radio. I have fitted a few over the years including my current 80 series. The problem l am finding isn't the fitting of the radio into the dash but rather where the heck to fit the aerial. I cant use a conventional bonnet/guard mount because of the shape of the bonnet and guard not to mention
the gap between the two doesn't allow for the coax without pinching it. I am beginning to think l will need to fit a nudge bar although not my preference. I would appreciate any ideas or solutions.
Regards.
Steven
Reply By: Kev M (NSW) - Saturday, May 19, 2007 at 20:43
Any chance it will fit around the boot??
Kev
| Russell Coight:
241074
Follow Up By: Member - Steven H (ACT) - Sunday, May 20, 2007 at 13:08
Thanks Kev forgot to mention it was a station wagon but thanks for the comment.
502066
Reply By: DIO - Saturday, May 19, 2007 at 21:01
Why not consider a glass mount. Police use them all the time in unmarked vehicles. Or perhaps a magnetic base.
241077
Reply By: Member - Doug T (W.A) - Saturday, May 19, 2007 at 21:26
Steven
Check out this web site
Site Link
241087
Reply By: Olcoolone (SA) - Saturday, May 19, 2007 at 22:12
We had a XR6 turbo and mounted a Icom IC2010 in it, the radio had a remote head that we mounted underneath the tissue box holder in that little cubby hole in the consol and we mounted the radio body under the
seat.
The antenna was mounted from the rear boot on a bracket we designed, the bracket has 2 holes in it for 5mm bolts, you drill 2 holes in the arm that lifts up the boot....not the body ...you then drill a hole in the body under the rear windscreen in the corner out of site to run the cable through.
The bracket we designed is contoured to suit the underside if the boot lid.
I can send you photos if needed ir sell you the bracket, the bracket is not something you can easly make at
home as it has steeped reverse folds, it toke me about 10 hours to design the first one.
We have full metal work and engineering facilities.
Regards Richard
Regards Richard
241097
Follow Up By: Olcoolone (SA) - Saturday, May 19, 2007 at 22:14
Forgot to add....the antenna lifts up with the boot lid.
I wont sign my post because I did it twice on the last one.
501994
Follow Up By: Member - Steven H (ACT) - Sunday, May 20, 2007 at 13:35
Thanks Richard but i forgot to mention its a station wagon so if possible i need to work something out for the bonnet front gaurd area. Appreceitae your comments.
502071
Reply By: DarrynJ - Sunday, May 20, 2007 at 09:15
Hi Steven, my work fits antennas on "Z" brackets to BA Falcons with no problems. Put it on the L/H side using the first mudguard bolt above the headlight. Run the coax beside the bracket and you should be right.
Regd's Darryn
241138
Follow Up By: Member - Steven H (ACT) - Sunday, May 20, 2007 at 13:38
Thanks Darryn but i cant work out the Z bracket as the gaurd isnt flat on the inside and sculpts back und the bonnet when closed. Is it a std Z bracket do you know?
502072
Follow Up By: DarrynJ - Sunday, May 20, 2007 at 16:45
Steven I don't know if its a special Z for the BA or just a normal one bent to suit. I don't have a BA work ute anymore (Rodeo 4X4 now) so I cant
check. The On Glass antennas sound ok, they have been around for years, people used to say they didn't work very
well but maybe they are better now. If you cant get a Z to fit then they sound the best option.
Cheers Darryn
502097
Reply By: Member QLD Steve & Lorraine Mc - Sunday, May 20, 2007 at 12:36
Hi Steven
I have a mate who mounted the UHF set in centre console & the aerial on the parcel shelf inside the car on a BA GT using one of those stubbie little aerials about 3' or 4 inches long and yes it worked quite
well. Good enough to know what was going on up ahead on the road.
Hope that is of some use to you, have a great weekend.
Cheers Steve.
241164
Reply By: Shane (QLD) - Sunday, May 20, 2007 at 12:49
Steven H,
I have a BF Falcon XR6T & it's fitted with a GME TX4400 in the tissue box holder. The antenna was a problem at first as you have said. The problem was solved by fitting a Laser Clear UHF 4.5 dbi Transparent Antenna which is omni directional & dual polarisation which fits over the rear view mirror onto the windscreen. You don't notice it there.The small cable plugs into the antenna, feeds just under the roof lineing, down the left door/winscreen channel & under dash to radio. It's size is only about 6x4 inches & I believe price is about $70. They were made for unmarked Police cars etc. The beauty of them is that they are vandal proof & don't let the world know that you have a radio. The output has been boosted on the UHF for additional performance due to fitment of enforcement frequencies.
241166
Follow Up By: Member - Steven H (ACT) - Sunday, May 20, 2007 at 13:45
Thanks Shane they look interesting will do some research. How did you find it for range?
502074
Reply By: Member - Stephen M (NSW) - Sunday, May 20, 2007 at 18:28
Hi Steve, what about the very small bar that bolts up where your number plate goes then your number plate bolts to that, there mainly used for
driving lights. They are available from supercheap and are about $70. Providing when you screw it up to where your number plate goes you have a metal backing earthing shouldnt be an issue should just earth itself via the two bolts. Cops use them for the lights above there number plates and I had one years ago on my camry mainly so I could put some
driving lights on it but didnt want a dicki looking nudge bar which will cost you in the vicinty of $400. Just a thought. Regards Steve M
241221
Follow Up By: Member - Steven H (ACT) - Sunday, May 20, 2007 at 20:05
Hi Stephen great suggestion i will
check them out. Thanks
502142
Follow Up By: PatNav - Monday, May 21, 2007 at 21:29
Hi Steven H
I have 2 of those little bars stephen M is talking about my son use to have his earial on them work of pitty ya not in NSW i could have thrown one your way
Cheers patnav
502435
Reply By: Member - Dalb (SA) - Tuesday, May 22, 2007 at 12:52
Hi Steven
I did not 'fit' my
UHF radio to my 2yo model Falcon coz it is a leased one and they dont like holes drilled everywhere.
For my
Kakadu trip last year I bought a GME TX3400 I think it is (the split one) and just had the small screen and speaker sitting loose on the centre console all the time. The main box with the speaker sat on the floor under my
seat and I could hear it OK. I bought a magnetic arial base which I plonked in the middle of the roof and feed the cable thro the back door up to the base and it sat there beautifully, even over the worst corrugations. Cant tell you which arial I had but it just looks like a phone arial.
By the way, all the advice I got was that the roof is by far the best place for an arial.
The whole thing worked
well, and also made it so easy to transfer the unit to my recently purchased Cruiser.
Cheers, Dalb
241569
