Thursday, May 17, 2007 at 14:28
The surf has a different radiator to the prado, so I'm not sure how relevent this info will be, but these are the typical causes of overheating for 1kz-te surfs.
Radiator blocked. (obvious one).
Viscous fan not working correctly (even if it sounds like it is, it may not be fully locking in and slipping)
Gearbox - ATF low or working the gearbox too hard (in the surfs the bottom tank of the rad is where the heat exhchanger/atf cooler is).
Generally with all of those it's normally only hard acceleration for long periods that causes it to overheat, but there will be no warning that it is getting hot until the guage all of a sudden shoots through the roof.
The prados have a 70 degree C thermostat so your running temp should be around 71/72 degrees c. Depending on how efficiantlly your rad is working your rad shouldn't get heat soaked until about 30 degrees c+ outside temp cruising at 110kph++, even then all that will happen is your running temp will increase up to what ever temp the viscous fan is set to cut in, then it'll drop back down again.
When there is something up the bleep ter it get's heatsoaked and runs hot (not that you would know as the temp gauge would still be on half). Then it doesn't take much (just a longish
hill or some soft sand or whatever) to bring it over the edge.
For example, the surf has a 90 degree thermostat. It sits at 91 normally, highway cruising 30 degrees + it stits at about 98/100 degrees, if there are hills, overtaking or the outside temperature get's hotter the viscous fan cuts in at about 102c then it roars its nuts off until the temp drops back down to 95c and cuts out, it'll cycle like that on and off all day if it has too.
But I can still get it hot if I'm overtaking up
hill or doing some really boggy sand sections because the temp goes up so fast the viscous fan doesn't get a chance to lock in in time and I have to back off until it does and then the temp drops back down again.
Don't know if any of this helps, hope it does! ;-)
501471
