is replacing nozzles as good as injectors
Submitted: Tuesday, May 08, 2007 at 20:39
F4Phantom
noticed on ebay they sell new injectors for diesels and other kits for just the nozzles. There is a cost benefit to only replacing nozzles but is the result the same?
Thanks.
Reply By: hiab - Tuesday, May 08, 2007 at 20:49
if your nozzles are carboned up not a worry, but i think you really have to pull them out and open them up and
check the spring and shims, if the spring is worn it will open early and overfuel. if you are not confident to do this as everything must go back in order and be spotless, i mean spotless. get a pro to do it, by all means take the injectors out yourself and save labour time, but when they are apart, cleanliness is vital. i think the shims come with a nozzle kit. i recently put nozzles in my 60 , but i have the luxury of a sealed fuel room at work. and you need access to a spray tester as
238665
Follow Up By: F4Phantom - Tuesday, May 08, 2007 at 21:00
thanks, thats a no to me, i will just get the full injector, do you know if i need to have the pump adjusted after i fit the new injectors?
499729
Follow Up By: Member - Stephen M (NSW) - Tuesday, May 08, 2007 at 23:05
Hi there Hiab, I owe you an apology for the other day about the rattle in the front end of a prado that was asked about on here. I thought you were being sarcastic thats why I replied about playing with your ipod. Sorry about the smart a#se reply I left you. Regards Steve M
499765
Follow Up By: hiab - Tuesday, May 08, 2007 at 23:14
no wuckers, i dont have an ipod anyway
499768
Reply By: hiab - Tuesday, May 08, 2007 at 21:17
you might have to if it is a bit black smoky, but east enough to do, but get a pro to do it, i have a piston i pulled out of a 4.2 nissan today and it has a hole in the top about the size of a matchbox, caused by a mate, "who knew a bit about diesels" playing with the pump and turbo boost, all the other pistons were cracked as
238682
Follow Up By: F4Phantom - Tuesday, May 08, 2007 at 21:45
thanks. i wont be taking any risks.
499745
Follow Up By: hiab - Tuesday, May 08, 2007 at 23:13
which is why i wanted to put the
pic on here but me no savvy how to do it
499767
