HJ75 Troop Carrier CAB and Ute CAB interchangeable?
Submitted: Monday, May 07, 2007 at 11:14
trooping
I have a troopy crumbling at the seams with rust. I want to take the cab off and put on a UTE cab, does anyone know if there are any compatibility issues? I know there are a couple of different mount points on the chassis for the tray that are not on the troopy chassis - however I will need to get a tray made up anyway so can probably cope with this ok - but what about the rest of the cab - are the chassis's different?
Reply By: hiab - Monday, May 07, 2007 at 11:50
same chassis, different mounting points but that can be overcome when you have your new tray made, just put mounts where needed.
238364
Follow Up By: trooping - Monday, May 07, 2007 at 15:44
thanks for your reply - is it only the tray mounting points that are different - or are the mounting points for the cab (troopy vs. ute) different also?
499491
Reply By: hiab - Monday, May 07, 2007 at 15:53
i reckon the forward mounts would be the same, but behind the seats may be different, climb under with a tape and see how it looks.
238401
Reply By: Allan JJ - Monday, May 07, 2007 at 21:27
As others have said, should be no problem putting the ute cab on the troopy chassis with a custom built tray.
You may find the last mount required for the rear most section of the cab may not be in the right place, but with an angle grinder & welder anything is possible.
The troopy actually has a longer chassis, if you look at the back it has an extension of about 75mm welded onto the end, which the ute doesn't have.
238468
Reply By: traveller2 - Tuesday, May 08, 2007 at 08:24
The chassis is also different at the back if you have the second tank or not as
238528
