Tuesday, May 08, 2007 at 13:28
Hi off-track,
To quote from your link to Beadell Tours;
S.B.R 4WD tyres are the best compromise for On-road and Off-road work. Steel plies under the tread of the tyre give strength and rigidity for high speed On-road travelling, while also giving the ability to bend and grip reasonably
well while Off-road.
The sidewalls are thin and supple, allowing little heat build-up at high speed thus reducing tyre wear. These same thin sidewalls can also be used as shock absorbers for Off-road. By letting your pressure down a few psi, the tyre will absorb many of the corrugations and potholes with ease. Most importantly it should reduce the risk of damage, as the tyre with less pressure will "give way" so an object won't damage it, (try popping a half flat party balloon). This makes travelling much more comfortable and less strenuous on the
suspension and chassis of your vehicle.
I agree with what they say. Don't run tyres so hard that the side walls are firm, and, they give both you and your
suspension a better ride.
What 4wd uses x-plys ? I reckon I would have more chance of getting a x-ply tyre for a Troopie ANYWHERE in Australia then you would looking for a radial (note I say ANYWHERE). But that is not the point, I am not saying you should use x-ply tyres. I am saying that you should not run radials so hard that they have a rigid side wall.
499654
