Fitting dual batteries in GU Patrol
Submitted: Saturday, May 05, 2007 at 09:05
ThreadID: 45113 Views:1989 Replies:3 FollowUps:1
I have the TJM fitting kit, just wondering where is the best place to fit the switch box. Has anyone fitted one of these kits.
Reply By: Bonz (Vic) - Saturday, May 05, 2007 at 09:13
u mean in the cabin or under the bonnet?
AnswerID: 238041
Reply By: Sand Man (SA) - Saturday, May 05, 2007 at 10:04
By the "switch box" I assume you mean the Isolator Unit?
Normal place is on the rear firewall in the Engine bay, central to the location of both batteries.
Bill
AnswerID: 238050
Follow Up By: Member - N C (TAS) - Saturday, May 05, 2007 at 12:58
I think you meam the led display that lets you check the level of each battery. If so I put mine just below the right hand vent and mounted it into the plastic
FollowupID: 499167
Reply By: Granpa Joe - Saturday, May 05, 2007 at 20:13
A dry place like the drivers side of the brake booster below and to the drivers side of the wiper motor is pretty good, remember that anywhere on the passengers side of the motor gets Quite hot from the exhaust manifold and turbo.
Hope this helps,
AnswerID: 238127
