How does this work
Submitted: Wednesday, May 02, 2007 at 13:12
ThreadID: 45009 Views:3542 Replies:13 FollowUps:45
I've been reading post 44944 with interest,but can someone please explain why tyres on a trailer, need to be let down when being towed on sand ?
I understand the concept letting tyre pressure down on a car, but it doesn't make sense to do it on the trailer.
My way of thinking is, If you lower the pressure on the trailer, you increase the foot print on the tyre, Would this not create more drag? as opposed to a higher pressure giving less foot print being less drag.
Can someone put this in perspective please.
Cheers Steve.
Reply By: Member - Roachie (SA) - Wednesday, May 02, 2007 at 13:18
Try to imagine riding a push bike over a sand dune. The thin tyres would sink into the sand and make it pretty tough going.
Same thing with the trailer tyres......let the pressure down, increase the footprint and save the tyres (all of 'em) from digging down and making a bow-wave in front of themselves which they are then constantly trying to climb over. It is a similar effect to the old story of the amount of weight exerted by a woman wearing stillettos (high heals)......she may only weigh 50 kgs, but if I had to have someone stand on my hand, I rather it be a 100kg bloke with the heal of his Blunney, than the petite little chick with the heal the size of a 1 cent piece!!!!
I hope this explains it a bit better....
AnswerID: 237389
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, May 02, 2007 at 14:17
I'l take my chances with the petite little chick thanks Roachie!! LOL!!!
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
FollowupID: 498433
Follow Up By: Des Lexic - Wednesday, May 02, 2007 at 14:31
Roachie, you'd prefer the petite little chick anyday. especially if she was wearing a short skirt.
FollowupID: 498439
Follow Up By: Pajman Pete (SA) - Wednesday, May 02, 2007 at 17:08
Only a banker could remember the size of a one cent piece!
Pete
Any mug can be uncomfortable out bush
FollowupID: 498456
Follow Up By: Bonz (Vic) - Wednesday, May 02, 2007 at 20:38
Reduce the tyre pressure and the footprint is wider and has more of a wave of sand to pull over
FollowupID: 498541
Follow Up By: Richard Kovac - Wednesday, May 02, 2007 at 21:37
Bonz
Reduce the tyre pressure and the footprint is longer (you can not make a tyre wider)
Richard
FollowupID: 498578
Follow Up By: Bonz (Vic) - Wednesday, May 02, 2007 at 21:40
Thanx Richard from what I have observed the lower pressure tyre is both wider (maybe 10% and heaps longer (up to 30%) I know what u mean
FollowupID: 498581
Follow Up By: Member - Roachie (SA) - Wednesday, May 02, 2007 at 21:53
Sorry Bonz, but I think your "10%" increase in width is being VERY generous, whereas the 30% increase in length is nearer to the mark. The tyre might "appear" to be somewhat wider, but the vast majority of that apparent increase in width comes from the bulge in the sidewall......only a tiny bit of it (like 2% tops) is transferred to the ground as increased width.
Just my opinion.......
FollowupID: 498586
Follow Up By: Bonz (Vic) - Wednesday, May 02, 2007 at 22:16
When I was on Fraser I did this measurement of width, measured the tyre track at 35 PSI then at 15 PSI it was noticeably wider and measure around 10-15% wider I havent got the actual measurements, also measured the depth of the track and that was shallower by about 30% too as I recall.
FollowupID: 498592
Follow Up By: Member - 'Lucy' - Wednesday, May 02, 2007 at 22:35
Bonzarelli
Admit it, you were observing and measuring something else entirely. (a leetle thing maybe)
In a past 4WD monthly this subject was done to death and to prove its length not width that increases they put a 4WD on glass stands/floor.
Photographed , measured and marked the tread footprint.
Lowered the pressure to 18psi or thereabouts and applied the aformentioned procedure.
Result: tread footprint lengthened. No increase in width except for a visual ballooning of the sidewall.
FollowupID: 498597
Follow Up By: V8Diesel - Thursday, May 03, 2007 at 10:11
Glass is flat and hard as steel. Does any one recommend letting tyres down to drive on steel plate?
Sand is 'fluid' and most tyre footprints in sand are a good 100mm deep. I dry sand it can go deeper than that.
Did they try various aluminium dinghey's on the same rig to show how they sit in the water? That is a flawed test.
I think it's a bit of both but clearly in favour of the length. Bagging out is bagging out IMO.
FollowupID: 498669
Follow Up By: Member - 'Lucy' - Thursday, May 03, 2007 at 22:53
V8Diesel
Your knowledge, experience and in depth appreciation of this subject is obviously second to none.
However in the interest of clarity and non obfuscated comment , you really must address your replies/thoughts on this subject to the author of the article in the subject 4WD monthly, who writes under the Pseudonym of - none.
FollowupID: 498874
Follow Up By: Bware (Tweed Valley) - Thursday, May 03, 2007 at 23:47
Interesting theory..... the length of the footprint is definitely the 'driving' factor but I think Bonz is on to something; in soft sand the bulge in the sidewall will make contact with the sand due to the 'v' shape of tyre track in the sand (as opposed to the glass experiment). Whether that extra contact is pushing through soft sand or aiding in flotation is another matter ;-)))
I
FollowupID: 498892
Follow Up By: Member - 'Lucy' - Friday, May 04, 2007 at 00:02
Mr Bware
I feel that in the interest of fairness I must bring to your attention that the only thing this BONZ character is on - is a 'higher plane of awreness'
He is in that/this state due to the fact he is currently tooling around in TD 100 series.
The effect of same is like your archtypical English gentlemen taking delivery of a branch new Roller or Bently.
They and he just drool, stare and babble like idiots.
Whilst he is in this besotted state, take whatever he says with the proverbial grain of salt.
There will be may pics of this state of affairs in weeks to come after the OBC 07 where he will displaying his and the 100series prowess in the outback, where it is tough, rough and mighty unclean, but not for a 100 series mean machine.
FollowupID: 498894
Follow Up By: V8Diesel - Friday, May 04, 2007 at 14:00
Lucy, for the life of me I can't understand this 'footprint length' argument only. We all know the length of footprint is by far the main factor (driving on 12 ply crossplies in that gutless desert sand tells me this) as I said, it but to say the bagging out of wide soft sidewalled tubeless radials in sand does NOTHING AT ALL because you've seen it on a sheet of glass just doesn't add up to me. Just having the 'U' shape must help. They also help when turning to run up and over the wall of sand as well.
The tracks look different for starters. That would tell me something. The tread width will remain the same when deflated (derrr) but the sidewalls most certainly DO get wider and DO come into contact with the sand. To say they don't do anything at all because you've seen them on a sheet of glass is a bit silly IMHO. Ever seen a camel foot (not toe;-)) It's a good visual aid but not in a 'real world' context. I reckon you want to 'float' over the top, not eat into it.
Here's the litmus test. I'll let my tyres down to 15psi and then run over your clenched fist with the sidewall and see if it does 'nothing at all'. I'm off 4x4'ing for two days next weekend along the WA coast and will be running my near bald road pattern fatties at low pressure for the trip because they seem to work well.
Anyway, I guess if it was in a 4x4 mag it must be the gospel so let's just agree to disagree. I'll make my own mind up. Either way it works, so in the long run who cares. More important things to worry about.
FollowupID: 498984
Follow Up By: Member - 'Lucy' - Friday, May 04, 2007 at 21:13
V8
Its like this.
When you air a tyre up or down the Dimensions do not change and by that I mean a 31in tyre does not suddenly become a 28in tyre or a 35in tyre just because I change the presures.
And this is more evident in the with - a 10in width tyre from tread block edge to tread block edge always remains 10in. Changing the air up or down will never ever make it a 12in width tyre.
(now having said all of that, there is a fraction of a change in Dia due to a bet of stretch but nothing to get excited about.
Sooooooooooooooooo! the only thing that changes is SHAPE.
This is the key to it all.
By lowering the presure the 'footprint lengthens' The width does not alter one iota.
Raise the presure and you can change the footprint to a 'ball bearing' size
Footprint = the tread area that contacts the earths surface be whatever it maybe.
Now for the side walls.
YES! these suckers do ballon out when the presure is lowered an straighten up when the presure is raised.
However on sand that is hot, dry and powdery the side wall shape does 3 fourths of nothing except push the sand out of the way.
If the sand is wet and stable like some beaches or the Simpson then you don't have to lower the presure in the first place (Most times - or just a bit)
The only time that the side walls come into play is in really deep mud and thats only for front tyres where you can turn them L/R. L/R to try ( Its esoteric as to whether it works or not) and increase the traction.
So there you have it - shape is the answer not dimesion change.
Hope this gives some clarity on the subject.
FollowupID: 499068
Follow Up By: Richard Kovac - Friday, May 04, 2007 at 21:22
Yes it would be like letting the air out of your inflatable boat to make it float better
FollowupID: 499070
Follow Up By: Member - 'Lucy' - Friday, May 04, 2007 at 22:06
V8
I think I may have a better way of explaining the theory of weight displacement via the wheels.
Imagine an army personnel carrier weighing 8-10tonnes on four wheels and tyres at 80psi attempting to drive on a beach, hot dry bottomless sane etc etc.
The sucker is going to sink to its guts.
However - replace those tyres with tracks and that mother just keeps laying its own track.
Back to your 4WD . Lower the presure and you lengthen the foot print anin so doing create a minutature 'track' (actually four of them).
So the lower the presure the longer the 'tracks' and the vehicle just creates 'own base' to roll along on.
There! piece of p i s s really.
FollowupID: 499100
Follow Up By: V8Diesel - Saturday, May 05, 2007 at 00:12
Lucy, I am fully au fait with the longer footprint and have no argument with it as you will see if you actually read what I have WRITTEN, not what you think I am saying. I fully understand the logic and principal of it, have no argument with it and have also acknowledged that the tread is a fixed width. I do get it, you are preaching to the converted.
BUT.......
I do not agree with the assertion that the bulging sidewall has no impact on floatation or general 'manners' in soft sand. As I said before, it would only stand to reason the 'U' shape would have to assist the tyre in not 'biting in' as you yourself said by "pushing the sand out of the way". A foot long tread with sharp vertical sides clearly would not be as desirable as a broad rounded bulging sidewall to displace the sand. Floatation is what makes it happen.
Richard, how is the boat relevant to this discussion apart from the fact we are talking about air?
Once again, I urge you all to go back and re-read what I've actually written, not what you think I am saying.
Anyway, as I mentioned before, who cares? - it works and that's all that matters.
FollowupID: 499117
Follow Up By: Member - 'Lucy' - Saturday, May 05, 2007 at 01:26
V8
Up until about 6 years ago I always thought it was the 'ballooning' of the side wall that was the cause and effect so to speak secret of sand driving.
However, those thoughts of mine were corrected as the years went on during which I became involved with the extreme 4WD Outback Challenge, ATECO competitions were a number of the competitors are tyre importers in their everyday jobs.
By asking them a zillion questions about tyres, pressures, bead locking, puncture fixing, rim straightening ets etc I now believe it is the tread lengthening that is the said secret.
By looking at the ballooning of the tyres I to would have thought there was some 'gain' there.
Maybe there is and maybe there isn't , I just think 'length not width' and everything is just fine and dandy.
I must say however that no one has every impressed me and taught me at the same time something I would never have believed, unless I saw it and that was:
Re seating the beads with a tad of shellite inside the tyre, trail up over tyre and 3 metres away, valve out, light shellite trail with a match, duck down, BOOM and fully reseated tyre on the rim.
Very impressive indeedy - if not with a degree of danger.
FollowupID: 499126
Follow Up By: Richard Kovac - Saturday, May 05, 2007 at 02:17
May be read a couple of Len's early book pre 60's he tryed wide tyres and went back to narrow
FollowupID: 499127
Follow Up By: V8Diesel - Saturday, May 05, 2007 at 08:48
Lucy, I repeat - I am fully conversant with the lengthening of the tread and concur. At no stage have I disagreed that this is not the main factor at play. All along my point has been the ballooning of a sidewall in a wide radial must have a beneficial effect and a sheet of glass is clearly not a fair representation of sand.
Richard, I am probably the most ardent and vocal advocate of split rims and crossply tyres for true 'off road' aka bush bashing on this forum. I am aware of Len's work and I worked professionally doing much the same stuff myself ie: NO tracks whatsoever and taking compass readings and bashing through the bush in the remote and often uninhabited regions of eastern WA. This was my full time daily occupation. Len used DC3 wheels from an old WW2 Dakota aeroplane from memory, not a modern day wide radial with a non agressive tread pattern.
I have driven many off road km's in desert sand and agree that skinny crossplies are fine for the job as I mentioned in my earlier post. This is how I knew the 'secret' of footprint. I have also made many posts advising against using big agressive mud type tyres for desert work.
Anyway I think we got our wires crossed a little here. I was making a point and you blokes were arguing a different one. I still invite any one to let me run over their fist with a sidewall and tell me it does nothing.
All good, have fun!
FollowupID: 499147
Reply By: Moose - Wednesday, May 02, 2007 at 13:24
G'day Steve
I think you'll find that the theory goes that the larger footprint means the trailer stays on top of the sand more and thus reduces the drag. Just like on the vehicle a higher pressure means the tyre travels through the sand instead of over it.
But I have my reservations where the trailer tracks in the fourbys wheel ruts. Surely then the sand is already compacted and thus the issue of the trailer digging in would be lessened significantly.
May depend on sand conditions - sometimes very soft and powery and doesn't compact much.
Cheers from the Moose
AnswerID: 237391
Follow Up By: Member - Davoe (Nullagine) - Wednesday, May 02, 2007 at 18:56
sand doesnt really compact anyway this is why they use it as bedding for pavers. Imagine using clay/dirt they would soon sink etc all over the place
FollowupID: 498486
Reply By: Robin - Wednesday, May 02, 2007 at 13:37
Hi Steve
I'm happy with Roachie's explanation - but offer another way to look at the problem.
We would all agree that narrow tyres (of same diameter/pressure)
sink further into the ground.
Imagine the leading edge of tyre were in touches the sand.
This leading edge is higher than the bottom of the tyre.
It represents a step that the bottom of the tyre has to climb up to proceed.
Because the narrower tyre has sunk further the step is higher and hence
harder.
Robin Miller
Robin Miller
AnswerID: 237395
Follow Up By: Gramps (NSW) - Wednesday, May 02, 2007 at 13:50
Robin,
"We would all agree that narrow tyres (of same diameter/pressure)
sink further into the ground"
This has been debated ad nauseam on every 4wd forum known. From what I have gathered and experienced ( to a small extent ) is it's more a matter of the LENGTH of the footprint NOT the width. The longer the footprint, created by lowering the tyre pressure, the better the going in sand. Width is virtually immaterial.
Now I'll duck for cover as the 'fat tyre brigade' launch another jihad against we skinny tyre users :)))))))
FollowupID: 498428
Follow Up By: Robin - Wednesday, May 02, 2007 at 14:14
Hi Al
Yes we agree - thats why I included (of same diameter/pressure) in my reply
to prevent those questions and keep answer simple.
Carrying my analogy further a larger diameter(or lower pressure) and consequent footprint increase makes angle of approach to the "step" shallower as you don't sink down , and hence easier also.
Robin Miller
Robin Miller
FollowupID: 498432
Follow Up By: Steve from Top End Explorer Tours - Wednesday, May 02, 2007 at 14:17
I understand the above comments, this would definitely work on a tyre being driven,
But a trailer is a dead weight, I just thought less tyre tread less friction.
I remember a few years ago trying to move one of my trailers in the front yard, it's tyres were deflated somewhat, because of lack of use over time, trying to move it was hard, after giving up, I pumped up the tyres and moving it around was significantly easier.
Another theory I have is would it be harder to pull a fridge on a trolley with the tyre pressure up or down?
I await your thoughts.
Cheers Steve.
FollowupID: 498434
Follow Up By: Gramps (NSW) - Wednesday, May 02, 2007 at 14:22
Robin,
No worries, understand what you're getting at.
Steve,
My thoughts would be that the trailer, without deflating the tyres, would still be 'digging in' no matter fat/skinny tyres. Dragging would be no different to driving.
FollowupID: 498436
Follow Up By: T-Ribby - Wednesday, May 02, 2007 at 17:05
I'm with you Gramps on the skinny ones.
One could argue that the wider the trailer tyre, the more lateral resistance.
T.Ribs
FollowupID: 498454
Follow Up By: cookie - Wednesday, May 02, 2007 at 17:08
Whether the tyre is driven or not makes no difference.
On a hard surface less contact area means less friction no question, but on sand the physics are totally changed, it's more like a boat where the further you can get the boat out of the water the less drag. In sand the more contact area the less sinking, hence less drag.
It's just like walking in sand, get yourself some big old school surfer joe thongs and you walk right across the top but barefoot your sinking in and working twice as hard.
Why not do the same experiment with your trailer on sand, or maybe with a bicycle wheel to make it easier.
FollowupID: 498455
Follow Up By: Steve from Top End Explorer Tours - Wednesday, May 02, 2007 at 17:18
So do you think this is relevant to tyre size.
EG: If you have a 750 /16 on a split rim, you would lower the pressure to say 18 psi to give you a wider foot print.
Hypothetically this then gives you a foot print the same size as my 265/75/ 16s do I now drop my tyre pressure or are they the same.
I'm a think outside the Square type of bloke.
Cheers Steve.
FollowupID: 498458
Follow Up By: Gramps (NSW) - Wednesday, May 02, 2007 at 17:46
Steve,
You've missed the point. It's NOT the width of the footprint that counts, it's the LENGTH.
FollowupID: 498461
Follow Up By: cookie - Wednesday, May 02, 2007 at 17:58
Well this is when things go to the another level of complication. My best guess is a reduced pressure skinny would have less drag than a high pressure fat with the same contact area. My reasoning is reduced pressures also make your tyre more flexible and more able to make a flatter contact area on the bottom. This means you are reducing the effect of trying to drive over the little hill of sand formed in front of the tyre. Say the tyre is at extremely high pressure and doesn’t deform at all eg is circular at the bottom, then you are constantly driving up more of a hill.
The other important thing is when reducing pressures you are actually increasing the length of the footprint more than the width. It’s an interesting experiment to measure the length of you footprint at different pressures by sliding a sheet of paper or card front and back of you tyre and measuring the distance between. You can actually almost double the length of the footprint going from say 40psi down to 12.
Would be an interesting experiment to measure the force required to pull a trailer with different size tyres and pressures. It's not as straight forward as it first appears.
FollowupID: 498465
Follow Up By: Steve from Top End Explorer Tours - Wednesday, May 02, 2007 at 17:59
Sorry Gramps
I missed your first post, All is understood and making perfect sense.
Cheers Steve.
FollowupID: 498466
Follow Up By: Gramps (NSW) - Wednesday, May 02, 2007 at 18:05
Steve,
No worries, I had a devil of a time coming to grips with it while watching the replies to a similar post a while ago. It's one of those classics on this forum like Toyota v Nissan, Coopers v BFG, etc etc etc :))))
FollowupID: 498468
Follow Up By: Bonz (Vic) - Wednesday, May 02, 2007 at 20:43
A tyre acting on sand is very similar to a vessel on water, i.e. they have a flotations based on the WEIGHT they are carrying, so that weight displaces an equal amount of sand so you either have a wide low lip of sand to push thru or a higher slimmer lip of sand to push thru. When Dr Karl did his famous corrugation experiments he deduced that the effort to overcome the wide and low was equal to the thin and higher lip, all things being equal. QED
FollowupID: 498544
Follow Up By: Member - 'Lucy' - Wednesday, May 02, 2007 at 22:39
Gramps
You are the man.
Terang Teror
You are a dud
FollowupID: 498599
Follow Up By: Gramps (NSW) - Wednesday, May 02, 2007 at 23:23
Hahahahaha give him heaps Lucy :))))
FollowupID: 498606
Follow Up By: Bonz (Vic) - Thursday, May 03, 2007 at 17:28
READ THE POST AGAIN hehehehe I KNEW the fishing would be good on this one....... and it caught the biggest trout, rofl the Lucy BigMouth Trout hehehehe
I said.......When Dr Karl did his famous corrugation experiments he deduced that the effort to overcome the wide and low was equal to the thin and higher lip, all things being equal. QED
.....was equal to.......all things being equal. it is not possible for this comment to be wrong
FollowupID: 498753
Follow Up By: Member - 'Lucy' - Thursday, May 03, 2007 at 22:55
Gramps
I know I shouldn't talk about this, but it really is obvious to one and all that BONZ went forth and multiplied last night.
Half his luck!
FollowupID: 498876
Follow Up By: Gramps (NSW) - Thursday, May 03, 2007 at 23:03
LOL frolicking was he hahahahahaha please, no more. The disturbing mental images could consign one to the home for the bewildered :)))))
FollowupID: 498879
Follow Up By: Bonz (Vic) - Friday, May 04, 2007 at 19:53
Lucy I dont want to een BEGIN to understand how you KNEW THAT
FollowupID: 499036
Reply By: MikeyS - Wednesday, May 02, 2007 at 13:50
Which would be harder? Towing someone over sand who is standing on a single water ski, or someone who is standing on a surfboard? You would expect the single ski to bog down far more than the surfboard. Same (or at least similar) principle applies to the amount of "floatation", or contact area, and hence pressure applied by a trailer, or any other tyre for that matter.
AnswerID: 237398
Follow Up By: Member - DAZA (QLD) - Wednesday, May 02, 2007 at 14:20
Hi All
It also depends on how the trailer tracks behind the towing vehicle.
Daza
FollowupID: 498435
Reply By: tuck 01 - Wednesday, May 02, 2007 at 14:28
It just does, Steve, orright?
Any theory that takes so many analogies to explain it, just has to be right, surely.
AnswerID: 237410
Follow Up By: Member - bushfix - Wednesday, May 02, 2007 at 14:37
ha ha
all general statements are false
FollowupID: 498441
Reply By: Des Lexic - Wednesday, May 02, 2007 at 14:38
I agree with the principal of letting tyres down including the trailer.
remember donkeys years ago, all the old Tmodels etc had really skinny tyres and those guys opened up this country. I know the rolling diameter of the wheel had a lot to do with them getting where they went but they never had 4WD vehicles in those days either.
AnswerID: 237414
Follow Up By: Gerhardp1 - Wednesday, May 02, 2007 at 16:21
When they got stuck, which they inevitably did, they didn't use a 4Wd to pull them out, they used a 4LD
That's a 4 Legged Drive - a horse, or two big blokes :)
FollowupID: 498449
Follow Up By: Member - Roachie (SA) - Wednesday, May 02, 2007 at 20:05
Hey Des, No doubt you can remember the days of the T model really well.....YOU WERE THERE .......AND you had a drivers licence.....hahahaha. Exactly how many christmases have you seen mate????? hahahaha
FollowupID: 498521
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, May 02, 2007 at 15:43
Hi Steve
I speak from experience here and have done tests with pressures.
I have a Supreme Getaway 16 ft and 6 ft wide. It has single axle independent suspension with the same track as my LC100 and weight fully loaded with 200L of water is 2400 kg.
When on soft beach sand I deflate the LC100 BFGs 285mm to 16 psi Front and 18 psi Rear. The caravan at 45 psi cuts into the sand and I travel in 2nd gear Auto high range. When I take my foot off the accelerator the car comes to a quick halt.
When I drop the caravan down to 25 psi the LC100 drives like it is on the road and even shifts into overdrive and car rolls to a gentle stop when I take my foot off the accelerator.
Closer inspection of the tracks in both cases show a difference of about a 2cm cut in the track.
Derek.
AnswerID: 237425
Reply By: Member - Olcoolone (SA) - Wednesday, May 02, 2007 at 16:03
14th wonder of the modern world.....
Regards Richard
AnswerID: 237429
Reply By: robak (QLD) - Wednesday, May 02, 2007 at 16:26
Steve
Would you prefer to pull behind you a boogie board or a plough?
Yes,, the lower pressures will create more drag (on the road) but your trailer sinking into the sand will create greater drag still.
R.
AnswerID: 237433
Reply By: Member - Oldplodder (QLD) - Wednesday, May 02, 2007 at 17:42
Seen it happen.
Tyres notlet down on trailer and the were just dragging through the sans like a plough.
Wheels not turning at all.
Standard box trailer with 14" wheels and 30 psi.
Let them down to 20psi and all OK., tyres ran over the top of the sand.
AnswerID: 237448
Reply By: Gob & Denny - Wednesday, May 02, 2007 at 18:30
goodday steve
there was a very good article about this a couple of issues ago in the vks magazine by joel fleming with pictures and all it was a very good explination
i will try and dig it out (no pun ) and scan it or if you go to vks home page you may be able to bring it up
steve
AnswerID: 237465
Follow Up By: Member - Ed. C. (QLD) - Wednesday, May 02, 2007 at 18:57
Site Link
Confucius say.....
FollowupID: 498487
Reply By: Middle Jeff - Wednesday, May 02, 2007 at 22:54
Hi Steve
Best way I have heard is stand on your toes on hard ground and then flat foot on hard ground, it makes no difference now go and try it on sand. The bigger footprint helps you "float" over the sand. As someone above said sand never compacts, easier to think of it as dry water.
Have fun
Craig
AnswerID: 237569
Reply By: Member - 'Lucy' - Friday, May 04, 2007 at 21:16
Steve
This post has attracted a record number of views, replys, baggings and counter baggings.
Just hope you are satified with the heatache, angst, professional forum antics and other diatribe you have caused with this post, not to mention the time wasted checking up on the followups just in case one 'missed something'.
ROFLMAO ( well done)
AnswerID: 237952
