oil change
Submitted: Tuesday, May 01, 2007 at 16:42
ThreadID: 44977 Views:2104 Replies:7 FollowUps:4
hi, looking at changing the oil in both front and rear diff. what else apart from the engine should i look at changing? i bought the car with 180 thou kms and did not come with a service book so I have no idea what has been done.
Reply By: Member - Troll 81 (QLD) - Tuesday, May 01, 2007 at 16:49
I would get all suspension and steering components checked out and get a major service done
AnswerID: 237163
Reply By: Member - Davoe (Nullagine) - Tuesday, May 01, 2007 at 16:59
If it has a service book or get the gregorys manuel and do everything stated for the 40,000k service
AnswerID: 237167
Reply By: Trevor R (QLD) - Tuesday, May 01, 2007 at 17:21
I would do g/box and transfer oil while you are going as well. Air oil and fuel filters. this should keep you busy untill someone else adds to the list.
Cheers, trevor.
AnswerID: 237170
Follow Up By: Member - lyndon K (SA) - Tuesday, May 01, 2007 at 23:07
I agree!! remember you with need a pump of some sort to get the oils back in. I bought a cheap one from super cheap than ran of a drill.
Mind you the amount of diff oil i've had in my hair, i don't do it to often now :)))
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
FollowupID: 498314
Reply By: Footloose - Tuesday, May 01, 2007 at 17:39
Ok I've obviously got old timers...what sort of vehicle is it ?
AnswerID: 237176
Follow Up By: Robin - Tuesday, May 01, 2007 at 17:53
I've deduced it must be a 4 or All wheel drive cause its got 2 diff's - any advance on this ?
Robin Miller
Robin Miller
FollowupID: 498189
Follow Up By: Footloose - Tuesday, May 01, 2007 at 17:57
I dunno. But if it's not a Toyo then I can't help much :(((
FollowupID: 498191
Follow Up By: Member - lyndon K (SA) - Tuesday, May 01, 2007 at 23:09
you not takin the bleep are you Robin? :)))
FollowupID: 498315
Reply By: Steve from Top End Explorer Tours - Tuesday, May 01, 2007 at 18:30
Hey Frank
The first thing I do when I get a new (second hand ) truck for my business is the following.
Replace Engine oil, front and rear diff oil, gearbox and transfer, grease all points, Inspect re-grease and or replace wheel bearings, replace oil, fuel and air filter and any other filters.
Then as at that date and mileage you can keep your own records and start you service records from there.
Cheers Steve.
AnswerID: 237190
Reply By: Member - Phil G (SA) - Tuesday, May 01, 2007 at 19:01
180k and no service history - theres only one answer - you need to do everything in the book. It would help if you told us what vehicle you have.
Valve clearances, Timing Belt, All gearbox, transfer case, diff oils, fuel filters, oil filters, wheel bearings front and rear, chassis grease, battery etc etc etc
Hope you have a spare arm or leg if you are getting it done by a workshop ;-))
AnswerID: 237205
Reply By: Peter - Tuesday, May 01, 2007 at 21:09
Whenever I've bought a second hand car I've done all the above mentioned changes, but also do the brake, clutch and power steering fluid. The brakes especially cope a bashing over a period of time. Normally costs me around $100 to have all 3 flushed and new fluids. Also replace all the belts and keep the oldies as spares. May cost a bit initially but I've never been stuck on the side of the road with a minor mechanical repair due to maintenance
AnswerID: 237265
