Ericsson R290
Submitted: Sunday, Apr 29, 2007 at 14:16
ThreadID: 44871 Views:3168 Replies:7 FollowUps:3
Has any one had any experience with this satellite phone? My wife and I are planning a big trip fron July this year and I think we need a sat phone as a safety backup. I have seen these on ebay but I don't know anything about them. Is is a good model? I have used a Telit 550 on the Globalstar network with my work and I thought that it had a few problems, eg the fine gold pins that connect the charger are quite fragile and too easily damaged.
Yabbo
Reply By: Member - Olcoolone (SA) - Sunday, Apr 29, 2007 at 14:44
very hard to get accessories, spare parts and suport plus they have a very short battery life.
Regards Richard
AnswerID: 236611
Reply By: Member - John (Vic) - Sunday, Apr 29, 2007 at 16:31
Andrew you should have a read of the following previous Post's on Global$hit before you contemplate buying a phone on thi service.
There is a very good reason why these phones are on ebay cheap.
Have a look at........
No 42786
No 42886
No 42152
AnswerID: 236637
Reply By: Phil P - Sunday, Apr 29, 2007 at 16:39
Hi Andrew,
I have had one for a few years. Works well (including Simpson,CSR & VIC High Country). They are very good value for money. Battery life is average, however if you are in the car, no problems as you can use it while charging it. They are also a GSM phone for when you are back in range. You need to manually switch it between Sat Mode & GSM Mode.
Phil P
AnswerID: 236638
Reply By: Member - Barry (NT) - Sunday, Apr 29, 2007 at 16:48
Hi I suggest don't. Look to alternatives.
I have seen a copy of a letter that basically says that they can't repair or replace some of their satellites and that the level of service may be an issue for some time.
It is a real problem in parts of Central Austalia.
I can't say too much more obviously.
Barry
AnswerID: 236642
Follow Up By: Member - John (Vic) - Sunday, Apr 29, 2007 at 17:25
Barry have a look at the posts I refer to above.
One of them has a copy of the letter you refer.
FollowupID: 497719
Reply By: Member - Barry (NT) - Sunday, Apr 29, 2007 at 17:59
Hi John
yes read your letter.
I have a different letter that admits the system is degarded and likely to be for some time.
Barry
AnswerID: 236659
Reply By: Member - Andrew Y (NSW) - Sunday, Apr 29, 2007 at 19:48
Thanks, once again I'm amazed at the wisdom and experience of the exploroz forum! I read the threads that Victor referred to and it seems that a Globalstar phone may not be the solution I'm looking for. A HF radio seems to be a better option. We are spending 3 months on the road leaving Sydney in July to go up the coast to Cairns, turn left to go to Broome via Kurumba, Roper Bar and the Gibb River Road, then home via the Tanami track, Alice, Lake Eyre and Broken Hill. We are towing a camper trailer with a 2006 100 series Landcruiser. I can hardly wait.
Yabbo
AnswerID: 236695
Follow Up By: Member - John (Vic) - Sunday, Apr 29, 2007 at 20:12
Hi Andrew
By Victor I think you mean me???
I have been called lots of names in my life, some not repeatable on here ;-) and will answer to almost anything.
I'm actually John, Victor is my VKS call sign - Victor 6352. The Victor means I am a Victorian member of VKS.
John (Vic)
FollowupID: 497757
Follow Up By: Member - Andrew Y (NSW) - Sunday, Apr 29, 2007 at 22:46
Sorry, John!
FollowupID: 497827
Reply By: Member - Olcoolone (SA) - Sunday, Apr 29, 2007 at 20:31
Andrew Y,
I think I would be getting a sat phone aswell as a HF radio.
The sat phone is good for staying in contact with family and getting help.
A HF radio is good for keeping in contact with the VKS network, when you radio in the record your travel plans and give valuable information about road conditions plus they are better with dealing with problems, brakedowns or emergancys.
When you radio in for help the repeat everything you said to them,firstly to get the details right and secondly some one monitoring may be very close to you and can render assistance. The VKS network is also better then you phoning someone for help and them getting it mixed up or panicing (especialy family and freinds)
Regards Richard
AnswerID: 236716
