Cobb cooker
Submitted: Monday, Apr 23, 2007 at 05:48
ThreadID: 44616 Views:4361 Replies:13 FollowUps:12
I need help from all you Cobb users out there. Yesterday I purchassed one and had to try it out imeadiately. Bought a bag of heat beads (the self igniting ones) and a 2kg, roast of lamb. I fired it up and waited for the coals to ash over ,put a cup of good red in the moat together with some herbs, sat the roast in with some spuds, it was pretty full, put the lid on and sat back with stubby in hand and waited for the prescribed two hours, then for another hour, all to no avail, the tucker was not cooked and I finished it off in the oven. Where did I go wrong? fuel, too large a load, liquid in the moat or what?. I know that the things work so is is obviously a driver problem, and help would be appreciated.
Cheers, Nev.
Reply By: Member - Troopytrek - Monday, Apr 23, 2007 at 06:38
G'Day Neville, If yours is a new stainless one some one was on here the other day talking about a bag that Cobb has bought out for helping with heat escaping through the stainless wire walls. Ours is the early one with the plastic bottom and generally if they say 6 beads i will put eight or so. After using it numerous times I dont beleive you would burn any thing very easily in it so i don't beleive it hurts putting a bit more heat in there. Keep trying I'm sure that you will be happy with it once you get the hang of it. Cheers .
AnswerID: 235213
Follow Up By: Russ n Sue - Monday, Apr 23, 2007 at 06:57
Neville, Troopytrek is spot on about the new stainless mess Cobbs. They let too much heat escape out of the side rather than rise up over your food. There have been many items about this both on this forum and other forums. You could probably fashion a sleeve to go around your Cobb, or get one of the sleeves that Cobb has produced. (Seeing as this issue is due to an obvious design flaw they should be giving the sleeves away!)
I also put an extra bead or two in mine, especially if I'm doing a sizeable lamb roast. You do need to turn the roast a bit more frequently in the early stages of cooking but after a while the heat intensity settles and you should only need two or three turns to complete the job.
The Cobb book does make specific mention about the type and quality of beads that you should use. I haven't used the self-lighting type so if you still have trouble after you have a sleeve for your Cobb, buy the regular "Heat Beads" and give them a shot.
FollowupID: 496263
Reply By: Sand Man (SA) - Monday, Apr 23, 2007 at 06:51
Neville,
Doesn't sound like you are the one at fault mate.
I suspect you may have a Cobb Premier. The one with the stainless steel mesh base. Yes?
Apparently there has been problems with these when using outside as too much heat is being lost through the mesh.
I believe the solution is to place a "bra" around the mesh to stop the heat escaping and that such a cover is, or will be, available from the Cobb distributors.
The Mark II Cobb Cooker has a solid black bakelite base and this problem is non existent. The Mark II is still available I believe and is the one I have.
I also use the self igniting Heat Beads® brand of briquettes and only use 7-8 to cook a roast. 2 Hours should be ample time.
Next time, try covering the mesh to reduce heat loss and then see how you go.
Bill
AnswerID: 235216
Follow Up By: Member - Robyn J (QLD) - Monday, Apr 23, 2007 at 18:25
The older plastic bases are no longer available. Had to replace our one this year after many years of use and they told me that only you can only have the stainless steel ones now, they no longer produce the plastic ones.
Robyn
Jenkie
FollowupID: 496435
Reply By: Teabag (Queanbeyan) - Monday, Apr 23, 2007 at 07:34
Neville,
I have a Premier which could be the same as yours and haven't had the issue's described above. Cooks roasts with ease, scones and bread without issue....I suspect that you have the incorrect beads. In the hand book it is quite adamant about what beads you should use. I bought the beads that are pictured in the manual......Hope this helps......
PS: If they say 6-8 beads, I have always used the higher number of beads..........
AnswerID: 235220
Reply By: Member - Nutter (QLD) - Monday, Apr 23, 2007 at 07:36
Gidday Neville , we have had both types of Cobb ,have the stainless one now, I agree with what the others above have said regarding heat escaping with the stainless so it takes a little longer to cook, when we do a lamb roast (full leg with bone in) we allow 3 1/2 - 4 hours of cooking time, using 8-9 beads to start with and turn roast after 1 1/2 - 2 hours, check after 3 1/2 hours to see if cooked. However if doing veggies as well we add another 3-4 beads after about 3 hours, so we take out the roast , we lift it out still sitting on the cooking plate then put the Cobb lid over the top while the fresh heat beads are firing up, once they are ready add the vegies and replace roast and lid and cook for another hour. We have found a difference in cooking time if you stack the cooking plate right up, don't know if it is because your are blocking the holes in the cooking plate therefore limiting the heat that can circulate, we normally wrap the veggies in alfoil an place in mote, then turn them after about half an hour, have found this to be quicker than loading the plate right up.
AnswerID: 235221
Follow Up By: Member - Nutter (QLD) - Monday, Apr 23, 2007 at 07:38
Ooops don't know what I did but didn't finish the thread. This is what we have found from our Cobb experience, hope this is some help.
See ya
Guy
FollowupID: 496270
Follow Up By: Teabag (Queanbeyan) - Monday, Apr 23, 2007 at 07:38
Interesting, our Roast leg of lamb with veggies only takes about 2 hours at most. Never really had the heat issue people prescribe......
FollowupID: 496271
Follow Up By: Member - Nutter (QLD) - Monday, Apr 23, 2007 at 09:52
Hi Teabag, we noticed a slight difference in cooking time of the two Cobbs however not what I would call huge. Regarding cooking time, the size of the leg of lamb is such that it only just fits into the Cobb,enough food for 5-6 adults including the veggies, however I have done roast chicken less than 1 1/2 hours, and smaller beef roast enough for two people in around the 2 hour time frame. We do use the Cobb alot at home so maybe the heat loss issue isn't effecting us as much, though always take it away camping and allow about the same amount of time, if it's not qiute ready just kick back and have another soothing refreshment, either way it's all good fun.
See ya
Guy
FollowupID: 496306
Follow Up By: Teabag (Queanbeyan) - Monday, Apr 23, 2007 at 09:57
Nutter,
Agree 100%, good excuse for another amber beverage or allows a little longer for the Red to breath......Noting the Red generally doesn't get too long to breath at the best of times......hehehehe
FollowupID: 496307
Reply By: Gramps (NSW) - Monday, Apr 23, 2007 at 07:53
We've got the Premier (stainless mesh one) model and I'm sure we did'nt have a problem with it. Only had it a couple of weeks so far. A good excuse to try it out again over the next couple of days :))))
AnswerID: 235222
Reply By: Member - Julie P (VIC) - Monday, Apr 23, 2007 at 09:22
I reckon its your heat beads - we were told when we bought it only to use the non igniting ones - and another couple who'd had theirs for a while said the same thing - also keep out of wind as this can dissipate the heat as well, I would think this would be especially so with the stainless steel mesh ones - the only time we have had any trouble with our old bakelite based one was in very cold weather in the wind, worked ok when we put it in a sheltered spot out of the wind.
Also you have got to have liquid in the moat, it is what helps the cooking process. And put the cooking tray on to get hot BEFORE you put the meat on to it, we also put our spuds etc in foil, and put them in the moat, taking them out just before we are ready to take the meat out, put them on the cooking tray, opening the foil, to let them brown up a bit. It's sort of like par boiling spuds I think.
jules
AnswerID: 235238
Follow Up By: Member - Ray - Monday, Apr 23, 2007 at 19:29
yep self igniting beads hane accelerant in them that (may) taint your food
FollowupID: 496464
Reply By: Member - MrBitchi (QLD) - Monday, Apr 23, 2007 at 09:27
The problem is probably the heat beads you're using. The self igniting ones are not much good IMO.
I've tried several types and only found one I really like. Can't remember the brand name off hand but can check tonight if you like. Cooked a roast and vegies last night in 2hrs.... Yummmyyyyy!!!
AnswerID: 235240
Reply By: Waynepd (NSW) - Monday, Apr 23, 2007 at 17:48
Hi Nev,
First up you must use the good quality heat beads this makes a huge difference. The ones they recommend in the book, you did read the book didn't you :), are the ones called Heat Beads
Secondly there is an issue with the impact of breezes cooling the oven. Mick O in an earlier post told of this fellow Klaus from infrontcamping who makes a range of canvas products www.infrontcampinggear.com.au/
At the moment he and and I are having some fun getting the sizes right but he has developed canvas bra which covers the mesh base. I used one this afternoon to cook some chicken pieces and there was a sturdy breeze blowing too. It seems to have worked very well.
I contacted him using the info email on the site and he was very prompt with his reply. A really nice bloke to deal with as well.
I also spoke to Brian Sinclair of Cobb at the 4WD Show in Sydney last Friday and he says that they are developing a similar product made from wetsuit material that also anchors the lid to the base for use on boats.
So that says they acknowledge that there is a problem and have a fix in the pipeline.
The plastic based model is now discontinued. The Premier is the one model they make now. So when (not if) you owners of plastic models break yours i guess you will have to replace it with the stronger mesh ones
AnswerID: 235344
Follow Up By: Member - Poppy (QLD) - Monday, Apr 23, 2007 at 21:35
Yes Waynepd, broke my plastic one at Easter after 2 years of use, so looks like I am up for the Premier,,, bugger
Cheers Ray
FollowupID: 496521
Follow Up By: Waynepd (NSW) - Monday, Apr 23, 2007 at 21:51
You did better than me Poppy.
I broke mine after 2 weeks, didn't like the trip to Innamincka in the campertrailer.
You won't regret the change to the mesh base its a hell of a lot stronger and if Klaus gets his canvas bras up and running there will be a cheap enough fix for the heat loss problems.
FollowupID: 496530
Follow Up By: Waynepd (NSW) - Monday, Apr 23, 2007 at 22:15
One more thing Poppy,
from your postv i am not sure if you realise that you can just buy the premier base (about $39 ... 6 months or so ago) you don't have to buy the whole thing again
FollowupID: 496544
Reply By: Sand Man (SA) - Monday, Apr 23, 2007 at 18:17
Mr. Bitchie & Julie,
I have not experienced a difference in heat between the self igniting (Easy-Lite) and standard type of genuine Heat Beads® brand of briquettes.
They are both of good quality. I generally use the easy-lite Heat Beads® and do not have an issue with heat quality.
Neville,
I would have to say that 1.5 hours is generally sufficient to cook a roast (we like our meat a little on the rare side) but if I "forget" two hours or so and the meat is still moist but cooked to our liking. I also put the veggies in at the same time (in the moat) and they are not under or overcooked when the meat is ready.
So I would say the Heat Beads® brand of briquettes is the important factor, rather than whether one variation of them also has a "easy start" property added.
I have also noticed that after the packet has been opened for some time, the "easy start" capability is diminished somewhat and you are then back to a "standard" briquette.
The Easy-Lite briquettes are a little dearer than the standard type and you can only buy them in a smaller quantity. (3 kilo bag, which still lasts quite a while)
The standard Heat Beads® can also be "encouraged" along with a dose of methylated spirits before igniting, but in either case you can also whack them on a gas burner for a few minutes to get them going properly. I do this if the beads have absorbed moisture which they tend to do over time.
Bill
AnswerID: 235351
Follow Up By: Member - MrBitchi (QLD) - Monday, Apr 23, 2007 at 18:34
Mate, must admit I haven't used a Heat Bead brand of self igniting beads, just other brands, so that was what I based my comments on.
I agree though that the Heat Bead type are the best. That's what I use, so must try the self igniting ones.
FollowupID: 496437
Reply By: Member - Michael J (SA) - Monday, Apr 23, 2007 at 20:29
Nev,
I too had my troubles,
use genuine 'heat beads' get to ash colour, put in roast..vegies and cheap red in moat.......good red is for drinkin;
2 hours or so,,,,,,yum
The trick is in the heat beads...
Michael
AnswerID: 235404
Reply By: Diver1 - Monday, Apr 23, 2007 at 21:03
ours is a good one but its gotta get used in the right condition....it took me a few chooks to get it right and then some more!!!
nathan, hwmbo , reckons to add a few more heat beads, never take the lid off and never use t when its windy!!!
the only thing i can cook successfully in the cobb is porcipine meat balls!!
dont give up , just keep on cooking at home before going anywhere with it!!
Laura
AnswerID: 235417
Follow Up By: Waynepd (NSW) - Monday, Apr 23, 2007 at 21:54
Use the right beads and practice, practice, practice
FollowupID: 496534
Reply By: Member - Jeff H (QLD) - Tuesday, Apr 24, 2007 at 01:11
It's almost too late in the thread to draw a response, but , for those with the new , flash Cobb, why not simply wrap the mesh in foil?
GEES, don't smother it, and,[ on legal grounds], please don't interpret my question as a solution. Ferdinand.
AnswerID: 235470
Reply By: Member - neville G (QLD) - Tuesday, Apr 24, 2007 at 05:41
Thanks for the multitude of information everyone, I will continue experimenting.
Cheers, Nev
AnswerID: 235473
