charging agm battery
Submitted: Wednesday, Mar 28, 2007 at 10:58
Member Dublediff(VIC)
Just purchased a 12 volt 100ah AGM and wondering what is the best way to maintain in when not in the car - I have the flyer battery box from Derek and it will be okay in this when I am using this vehicle, but I need to use it in other situations in other vehicles, what is the best, long term remedy. Thanks, Eric.
Reply By: Gerhardp1 - Wednesday, Mar 28, 2007 at 11:03
I have one in the Camper, and it sat for 6 months between uses. Still had 13.6 volts, so the best way to maintain it when not in the car is probably to do nothing.
They have a long shelf life, but if you want you can use one of the low output 3 stage chargers and leave that on all the time.
Not necessary in my view.
230206
Reply By: Member - Battlecat (WA) - Wednesday, Mar 28, 2007 at 12:37
Hey Dublediff,
The main thing that kills batteries is scale on the plates - the best thing to do each month is boil the battery. Scale forms through general use but happens when you cycle the battery (run it low or empty). Mega pulse and Rotronics Dual Battery Kits do similar things in they revive and keep the battery free from scale.
230224
Follow Up By: Member - Peter R (QLD) - Wednesday, Mar 28, 2007 at 14:10
I have a Ctek7000 charger , which goes through 5 stages, and used this when in a caravan park to recharge battery whilst running fridge off 240v.
At
home I periodically ran the charger just to ensure battery was topped up, and to restrict sulphation.
The beauty of an AGM battery is that they do not lose their charge at a fast rate.
Pedro
491050
Reply By: Mike Harding - Wednesday, Mar 28, 2007 at 14:24
AGMs are very tolerant of lack of maintenance BUT are not immune to it.
Ensure that the battery is fully charged before you put it into store.
Ideally, maintain a permanent "float" charge on the battery of approx. 13V8 -
check data sheet for exact number.
Less ideally (but still pretty good) every month or two, at most, apply your normal battery charger to it and ensure it is fully charged. (This is what I do).
Mike Harding
230243
Reply By: Gronk - Wednesday, Mar 28, 2007 at 14:25
Charge it up, then leave it !!
Check its voltage every month and if it gets down to 12. 5 ( anywhere close will do ) give it a top up !! Simple !!
I don't like the idea of having a charger ( no matter how good it is ) trickling the batts that are deep inside the CT for days or weeks at a time !! No need to so I don't..
Now lead acid would be a diff story !!!
230245
Reply By: Member Dublediff(VIC) - Thursday, Mar 29, 2007 at 18:08
Thanks for the info, after an expensive purchase I started to panic that I would kill it like a gell cell I killed once, Cheers Eric.
230494
