Store my Triton
Submitted: Monday, Mar 26, 2007 at 16:34
Member - John B (WA)
Im working abroad for a year with a six month first stint so my 2005 Triton MK5 needs to be stored. I have contact Mitsubishi and they say just disconnect battery. Others have said jack it up and empty the engine. Has anyone stored their car for a while? Any tips u can give me?
Reply By: Member No 1- Monday, Mar 26, 2007 at 16:45
6 months aint a long time
i'd keep it in running condition charged with new oil. Brakes may become a problem after six months of no movement
better still if some one could start it once and a while while your away
and to at least
check oil for water/coolant leakage you didnt know you had
229845
Reply By: Exploder - Monday, Mar 26, 2007 at 18:17
This is what I would do.
Remove battery
New Oil and filter
A. Full tank of fuel> and add that Fuel storage stuff to the tank, B> Completely drain the fuel system.
Wash and polish it
Vacuum it out spotless
Lay a sheet of black plastic down in the shed to park the car on top of (Keep mosture out of the underbody.
Put it on Jack stands so the
suspension hangs free
Leave the hand brake off.
Put a car cover over it.
Spray some CRC Long life/ poor a bit of Oil into the cylinders to keep and corrosion at bay.
Cheers.
229860
Reply By: Member - Kiwi Kia - Monday, Mar 26, 2007 at 18:29
If you are not in a harsh damp climate just remove the battery or get someone to run it round
the block once a month and be prepared to get a new battery when you return.
229863
Reply By: Garbutt - Monday, Mar 26, 2007 at 21:02
Whay would you fill it up then drain it?
gb
229897
Follow Up By: Blaze - Monday, Mar 26, 2007 at 21:39
Garbutt,
I reckon the best way would be to lend to us to do the Canning, we could keep lubed up and charged, and save the long drive to WA LOL
490681
Follow Up By: Garbutt - Monday, Mar 26, 2007 at 21:53
Yep we could make sure the battery didn't go flat, no worries.
And
John B can trust us, after all we're members!
490686
Follow Up By: Exploder - Tuesday, Mar 27, 2007 at 18:29
Ether A> Fill the tank completely
B> Drain the Tank completely
One or the other not both
Hope that clears it up
490864
Reply By: Member - Bob K (SA) - Monday, Mar 26, 2007 at 21:34
I lived in Brunei for 3 years, came
home once a year for a month and all I did was get a friend to charge or replace the battery with a cheep one, get some rego on it and it was ready to go.
229909
Reply By: Leroy - Monday, Mar 26, 2007 at 21:38
I was away for more than 6 mths and had a mate take my VT crapoladore for a run every 2 weeks. I would just make sure the hubs were locked in for the ride also.
Leroy
229910
Reply By: smort - Tuesday, Mar 27, 2007 at 06:14
John B
six months is a very short time - son had a mitzi not a triton but a magna - away two years - put one of those very cheap solar panels from the warehouse on the battery direct connection - not through the cig lighter - nothing else - no drain of petrol no drain of oil no drive aroound
the block every little while - nothing - hopped in on his return - started first hit and drove it off.
Hope this helps
229950
Follow Up By: Member No 1- Tuesday, Mar 27, 2007 at 07:32
a mitzi....your pulling the wool over our eyes..hehehe
490743
