Sunday, Mar 25, 2007 at 11:01
Stephen,
Regarding recovery:
- Your recovery points will be the two large wire loops on the front and your square hitch towbar at the back.
- I'd suggest you buy an equaliser strap, an 8000kg snatch strap and two 3 1/4 T rated bow shackles. The equaliser strap and shackles are required for your vehicle to be safely pulled from the front. And for the rear, a strap can be safety inserted into the square hitch and retained by the towbar's 14mm pin. Snatching can be pretty dangerous, so I won't go into that, but you'll learn from a club or course about how it can be done safely.
Blue Tongue compressor is a good choice. I have
mine mounted on a piece of 2mm Aluminium sheet and is bolted against the inside panel forward of the battery. Compressors have a high amp draw, so you need a thick cable going to them if you want to mount in the back.
Winch - I'll leave that to someone else :-))
Radio - UHF - fits nicely in the dash if you buy a DIN size unit with front speaker (like say the Uniden UH-088). Can also buy a top shelf and mount up there. Aerial is best gutter mounted on drivers side where its nice and high. I use a swing down mount, and 95% of the time, I only use the 6inch rubber aerial which is unbreakable and transmits
well. I'll change it for the 60cm one when I want maximum range. If you want a bullbar mounted aerial to work
well on a troopie, it needs to be big, and even then the people behind you may get scratchy transmissions.
Uneven tyre wear is not usually due to shocks.
Check tyre pressures, wheel alignment first. Depends of where they are wearing - if its the inside of both front tyres, it may be a bent axle housing, outside may be low pressures, or toe in etc
Greasable shackles potentially improve ride a little on the older models with leaf springs all round, but only make a minor difference for what they cost. IMO they are pretty useless on the post 1999 models. I'd see how the vehicle goes, but
suspension is expensive to replace on the leaf sprung troopies.
490373
