1hz fuel pump
Submitted: Sunday, Mar 18, 2007 at 22:18
fishaholic
can anyone tell me how to back the fuel pump back a little?
Reply By: Member - Steve T (NT) - Sunday, Mar 18, 2007 at 22:26
Hi Fishaholic
This one is a job for the professionals, trust me.
Take it to someone who does fuel pumps and injectors.
Cheers Steve.
228221
Follow Up By: fishaholic - Sunday, Mar 18, 2007 at 22:32
you will be sick of sorting my probs out soon lol
489008
Reply By: Allan JJ - Monday, Mar 19, 2007 at 05:20
I agree
Get someone who know what they are doing.
It could will end up costing you if you get it wrong
228237
Reply By: Member - Nick (TAS) - Monday, Mar 19, 2007 at 08:29
Easy one mate.On the back end of the pump where the injector pipes come in there will be a threaded rod with lock nut on it(if its still factory set it will have a bullet shaped cover over it).Get some one to watch your rpm's and screw it in to lean it off and out to richen it.About a quater of a turn will drop 250rpm off the tacho(did
mine).Cleaned up the smoke(lots) in ours and didnt effect power at all.In fact ours runs smoother and revs crispier(like our weather) than before.
228258
Follow Up By: Middle Jeff - Monday, Mar 19, 2007 at 09:37
What he said, easy as. You are only adjusting the fuel flow not changing the pump timing.
Have fun
Craig
489078
Follow Up By: Member - Tony J (NSW) - Monday, Mar 19, 2007 at 12:10
"screw it in to lean it off and out to richen it" - are you sure??? My manual says turn it in to increase fuel and out to lessen fuel.
Tony
489092
Follow Up By: furph - Monday, Mar 19, 2007 at 13:23
The threaded screw has a locknut and a crimped/spot welded sleeve to prevent it being turned further in.
Further in (clockwise) increases fuel, out (antic/w) reduces fuel. Try turning 1/2 to 3/4 turn out for reduced smoke at under load conditions and a 10/15% improvement in fuel economy. You will notice the need to use the gears more, there is a power drop off. Big benefit in keeping the oil cleaner for a longer period though. Did this to
mine whilst quite new. Just back from a 2000km. trip towing a 15' van at 13.8l/100km. Now done 180000km. ('97 mod.)
489096
Follow Up By: Member - Steve T (NT) - Monday, Mar 19, 2007 at 17:17
Fishaholic
Trust me mate take it to a profesional, youv'e spent all that money so far spend a bit more and get it right.
489133
Follow Up By: Member - Nick (TAS) - Monday, Mar 19, 2007 at 18:32
Yeah may have got it back the front but if you watch the revs you will know.
489149
