Thursday, Mar 15, 2007 at 18:49
Many thanks for taking the time to reply
The Fridge is an Engel 40th Anniversary 40 litre model.
Powered by a 100A/H SLA via a Redarc isolator.
Before that the dual battery was a 80A/H and we used to be able to run the fridge for about 3 days without starting up the truck.
After leaving the
campsite on Tuesday we had a 7 hour drive
home and after emtying the fridge I put a few ice blocks in it and left it switched on (number 1)
The battery is now showing 10% charge and the fridge ran for 40 hours.
I know that you shouldn't run down the battery that low, but this is the first time.
I am a little surprised that we get less time out of the 100A/H battery than we did with the 80A/H
In the last few weeks though I have made a few modifications.
1. I have ran a length of 6BS twin battery cable to the rear of the truck next to the trailor socket and terminated with a 50amp Anderson ready for when we pickup our Adventure off road trailer. This is protected by a 100amp fuse.
Maybe there is a voltage drop, I will have to measure the voltage at the rear Anderson when the battery is charged again. I did measure this once and it was 12.7V from memory
2. I have added a opposite lock dual battery monitor with alarms.
The 100A/H battery sits next to my starting battery under the passenger
seat.
IT is a SLA battery that I purchased from Jaycar, maybe tthat is the problem!
It doesn't like the
Birdsville track! And can't handle the rough stuff?
The Trailor is supplied with a 100A/H battery and when I know what type and brand maybe I will purchase another one so that I have two the same and get rid of the Jaycar one.
The idea is that whilst driving with the trailor my dual battery will be in parrallel with the trailor battery both charged via the Redarc.
I guess having now got rid of the rooftop tent we will no longer be in one place and will be able to drive around, explore and charge the battery backup
cheers and thanks for the replies
227693
Follow Up By: drivesafe - Thursday, Mar 15, 2007 at 19:34
Nice set-up Pomgonewalkabout, one point I would raise is the use of a fuse and the size of the fuse.
Circuit breakers are much safer than fuses in high current circuits and in either case, 100 amp fuses and circuit breakers are designed to be able to handle 150 amps for nearly 1 hour before going open circuit and can handle something like 200+ amps for around 5 minutes.
This high current handling is deliberately designed into these devices to allow them to handle the near dead short that occurs every time a motor starts, IE like your fridge motor.
In your set-up, a 30 amp circuit breaker near the positive terminal of your auxiliary battery under the
seat and, then you install the battery in the trailer, an other 30 amp circuit breaker near this battery’s positive terminal.
Using this sort of set-up not only gives you dead short protection ( which the 100 amp will but may actually take a second or two to blow ), in a dead short situation, the 30 amp set-up will go open circuit much MUCH quicker but the 30 circuit breaker set-up also gives you overload protection. The 100 amp set-up in an overload situation could actually allow the cables to melt before the protection goes open circuit.
Cheers.
488444
