is your speedo cheating you?
Submitted: Wednesday, Mar 14, 2007 at 05:04
Member - extfilm (NSW)
Are we being ripped of with warranties on new vehicles?
Just saw a story about 2 reputable car manafacturers having their speedo's reading incorrect by as much as 2%.
Which proves why my speedo reads 107kms an hour and my gps reads 100km/h. I just put it down to having different tyres on the car and had not got round to doing the figures yet.
With my car that equates to approx 5000 to 6000 kms of lost warranty?
Site Link
The story said that at least 1 of the manafacturers new about this problem but opted to say nothing and have rectified the situation in their later model (07) vehicles.
A lawyer in America has won a battle with the above company giving owners of these vehicles an extra 6 months warranty.
Reply By: Richard W (NSW) - Wednesday, Mar 14, 2007 at 05:31
I'm running larger tyres. ;)
227305
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Mar 14, 2007 at 09:37
Same here.
Paj odometer is under reading by 5% with larger tyres.
95k is actually 100k when travelling.
So if I have done 260,000k on these larger tyres, do I admit that the car has done 273,000k when I sell it?
Do I admit oil changes are done every 5250k instead of 5000k?
488135
Follow Up By: Member - Doug T (W.A) - Wednesday, Mar 14, 2007 at 10:41
Oldplodder
Physically it has done said distance but Mechanically it has not
488142
Reply By: Baldrick - Wednesday, Mar 14, 2007 at 08:02
Legally a manufacturer is allowed up to 10%, but it's not allowed to read slow which means yes, normally the indicated speed will be faster than the actual speed.
227325
Reply By: Robin - Wednesday, Mar 14, 2007 at 08:27
Hi Extfilm
Most likely you are not being cheated.
While your speedo reads 107 this error is not usually reflected in oddometer readings, in a standard car.
In fact if you
check the speedo with GPS at 50kmh you will probably not see the 7% error as it is usually non-linear.
On ones I have validated (GU Nissans) the speedo is deliberately designed to read high whilst the oddmeter stays within 1 - 2% on unmodified cars.
Robin Miller
227329
Reply By: Andrew from Vivid Adventures - Wednesday, Mar 14, 2007 at 08:35
Don't worry Pete,
Most manufacturers aren't arguing about the things that happen in the last 10K's or just over 10k's of a warranty.
If you have a serious problem at 110k's they will fix it in my experience.
Andrew.
227332
Follow Up By: Bilbo - Wednesday, Mar 14, 2007 at 20:27
Unless you own a 3.0 litre Nissan,,,,,,,in which case,,,,,,,,,,,,,,,,,,,,
Bilbo
488232
Reply By: Rock Ape - Wednesday, Mar 14, 2007 at 09:31
Well there is an upside to speedo's that read high, flash car got me at 2 in the morning the other side of
Bowen.
Ticket arrived and said 111k/h, 1point and 90 bucks. The reading on the speedo at the time was approx 120k/h.
Sometimes good comes from bad
Have a good one
The Ape
227344
Follow Up By: Darren C - Wednesday, Mar 14, 2007 at 10:34
That means he must have clocked you at 113 - in WA the cops always take 2km/h off the actual reading to take into account error.......
488140
Follow Up By: Rock Ape - Wednesday, Mar 14, 2007 at 10:57
Darren,
It was in a 100k zone, it is normal for Qld to allow around 10% over on the highway, so would say the 111k was the actual spped they clocked me at.
The Ape
488148
Reply By: Darren C - Wednesday, Mar 14, 2007 at 10:43
Out of interest has anyone experienced any difference between gps readouts and what they been clocked at by the cops?
I was told at time of purchase that my bigger tyres would result in a 3% underreading on my speedo. Currently its 5% underreading according to the GPS which would confirm the 1-2% "stock" errors mentioned above. This 5% is consistently shown even at speeds down to 50kph.
As such, have been relying on GPS to determine actual speed but not sure if these are any more reliable than the speedo!!
Darren
227363
Follow Up By: gottabjoaken - Wednesday, Mar 14, 2007 at 13:37
I'd be a little wary of relying on the speed calculation from a GPS.
The GPS is accurate to a few metres at best. The speed calculation is done from a point to a point over a small time.
If point A is determined, but the coordinates are actually a metre behind you and point B is determined but is actually a metre in front of you, then the calculated speed could be
well out.
It may be smoothed and I guess averaged, but it is no more of a reliable figure than your speedometer is.
IMHO
Ken
488157
Follow Up By: Flash - Wednesday, Mar 14, 2007 at 13:56
Most, but not all GPS's are very accurate.
Some do some "rounding" , (eg:my Navman PDA navigator), however a good unit which will give a speed as eg: 99.5 Km/h (like my Lowrance GPS) will be far more accurate in a straight line than any speedo.
488160
Follow Up By: pjchris - Wednesday, Mar 14, 2007 at 16:50
GPS receivers do NOT calculate speed from a point to point over time scenario.
From gpsinformation.net :
"GPS receivers typically calculate velocity by measuring the frequency shift (Doppler shift) of the GPS D-band carrier(s). Velocity accuracy can be scenario dependent, (multipath, obstructed sky view from the dash of a car, mountains, city canyons, bad DOP) but 0.2 m/sec per axis (95%) is achievable for PPS and SPS velocity accuracy is the same as PPS when SA is off."
One caveat is that most consumer GPS units report speed over ground and ignore altitude changes so when the GPS says 100kph going up/down a steep
hill you are actually going faster than that as the GPS reports speed in the horizontal direction only.
488191
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Mar 14, 2007 at 18:57
Was looking at using the GPS as an aid for navigation in a rally car.
Worked out that a GPS only gets a reading from the satellite about once a second, which at 160km/hr is about 60m, or more.
Also found recording a track that the track log showed speeds of over 200km/hr.
Not that accurate.
488216
Follow Up By: pjchris - Wednesday, Mar 14, 2007 at 21:27
Actually the GPS is receiving signals from the satellite continuously it just outputs once per second. Tracks that show 'spikes' of ridiculous speeds were more common with earlier (less sensitive) chipsets, I use a SirfStar II or III chipset and as long as the unit has clear reception it doesn't do this.
This means, generally, using an external powered antenna on the roof of the car as most track errors are to do with momentary loss of reception of one or more satellites and even my most sensitive GPS works best with an external antenna.
To illustrate, even with an external antenna the momentary loss of signal caused by passing under a freeway overpass causes the GPS to report a slightly different speed (In my case lower by 2-3 kph)
488248
Follow Up By: Member - Oldplodder (QLD) - Thursday, Mar 15, 2007 at 21:36
Thanks for that pjchris, I have sirfII. Son was trying it out when he navigates, but the speeds are too high (100 to 250+ depending on route) and with the interfernece of tree cover, it doesn't work as
well as we hoped.
488471
Follow Up By: pjchris - Friday, Mar 16, 2007 at 00:38
I drive (semi-competitively) through the pine forests and bush around
Mount Gambier once a year and with an antenna on the roof it tracks beautifully, never losing lock and we don't get strange speeds in the track log either.
488522
Follow Up By: Member - Oldplodder (QLD) - Saturday, Mar 17, 2007 at 20:14
Thanks,
Might try it with an external aerial.
Bit late for the QRC round in a couple of weeks.
But might be good in the beetle or friends EVO VIII, they don't get much over 220/230.
488802
Follow Up By: Im.away - Sunday, Mar 18, 2007 at 01:15
I use a re-radiating antenna as
well. This enables me to locate the receiving antenna where it gets the best "view". I rarely get dropouts and I use the display function in OziExplorer that enables me to watch the number of satellites I am receiving and the strength of the received signal. This is how I can confirm that the dropouts are minimal.
Like the others with a similar system, I get very reliable speed readouts that I have had confirmed by Police radar.
488859
Reply By: whyallacookie - Wednesday, Mar 14, 2007 at 16:02
Except of course, as mentioned the GPS is basing it on point A to point B, so even if it was exact, (which we all know they aren't, and the error is variable) they do not take in to account terrain (small dips and crests) and corners.
227414
Follow Up By: pjchris - Wednesday, Mar 14, 2007 at 16:51
see follow up above
488192
Follow Up By: whyallacookie - Wednesday, Mar 14, 2007 at 16:56
Well put. Of course most of us buy the "consumer" versions
488193
Follow Up By: Bonz (Vic) - Sunday, Mar 18, 2007 at 08:06
why...The error of a GPS is determined bu singal cloud etc etc etc, over the period of the measurement and distance, this can be taken to being a constant, hence GPS's even in common use are about 0.2 kmh accurate.
I dont have the doppler equivalent but
488864
Reply By: Mike Harding - Wednesday, Mar 14, 2007 at 18:28
Having, not too long ago, done the design of the speedo and odo for a car now selling in large numbers in the Oz market you would _not believe_ how much effort (read money) goes into ensuring they are both correct.
Mike Harding
227453
Follow Up By: Bilbo - Wednesday, Mar 14, 2007 at 20:31
Looks like all your effort was for nothing, Mike,,,,,,,,,,,,
Just jokes, Mike, just jokes,,,,,,,,,
Thanks for your effort on my behalf anyway.
Take care,
Bilbo
488234
