Thursday, Mar 01, 2007 at 15:27
Hi PoppyG,
So far the wet has been it's normal unpredictable self, the area around Drysdale ( central North
Kimberley) has been exceptionally dry.
The BOM site says something along the lines of El Nino being in effect but moving away and a greater than normal chance of later rains this year.
I never believe it till it happens but I will say that several times when we have had very small rain till end of Feb ( so far we have only had about 360 mm total wet ) it has then poured down in March and even early April. One year it was real dry by end March so got staff in and were ready to open by about 8 th April just waiting on road to be opened, cyclone went past down coast and by 13 th April the
Drysdale River was 27 meters deep at crossing. The road didn't even open till 9 th June, this is the only time in over 20 years I have seen it that late. June is normally pretty safe but honestly I have long given up expecting to have a ' normal ' wet season, there is no such thing !
All that can be said is Drysdale will get between 600 mm and 1500mm and it will fall between Oct & April and it can be steady and evenly spread or nothing much for weeks at a time and then almost all the rain then falls in a couple of huge dumps only which can happen at any time over the wet.
It's not so much a mater of bogged or not anymore, it's if the road has been legally opened or not. Everyone is so sick of a few people making a huge bog mess of the road by trying to force through before it's dry enough to take traffic, they are getting much tougher with fines and I am sure the local shire is becomming more pro active re stopping it happening.
We now simply don't open, won't serve at all, till the day the road legally opens.
I wish I knew what it may do just as much if not more than you do. Every year we are either ready too early ( waste of wages) or a mad panic to open same day as the road does. Takes a lot of work to re open after 6 months closed and takes a while to do it, so advance knoweldge would be great !
June is normally nice even if we do get a small wet as the
water won't have gone by then and the chance of it being too wet to get through is pretty low especially if it's later in June you refer to.
cheers, Anne
224764
Follow Up By: PoppyG - Thursday, Mar 01, 2007 at 16:04
Hi Anne
I really appreciate you insightful comments. I have been reading about the problems the stations etc are having with us tourists. Hopefully we'll do the right thing and respect the people and the environment. However, its good to get a local view on conditions and roads etc. It makes the weather pattern a mystery and all the more reason to see the
Kimberley's. I beleive the only down side of visiting up north in June is all the other tourists converging on the
Gibb River Road at the same time. PoppyG
485734
