Carry 2nd spare in the car, or on the CT.
Submitted: Wednesday, Feb 21, 2007 at 20:35
ThreadID: 42566 Views:2762 Replies:6 FollowUps:11
Ok, we have gone for luxury and ditched the roof rack and tent, and bought a CT. :O0
So I have the car spare on the back door of the car, and a spare on the CT for the CT.
But when we used to travel remote, we used to carry a 2nd spare on the roof rack.
Now we are trying not to use the roof rack, since all of the gear goes in the CT.
So when we are away from the CT on a day trip, hopefully going places we couldn't go with the CT, how do we carry the 2nd spare for the car in the car?
Bit worried about 20 plus kilos of tyre loose in the back behind the safety barrier.
So thinking of making a bracket to bolt it in the back, or else a bracket in place of the back seat.
What does every one else do with a trailer.?
Or should I just put the car 2nd spare on the CT and leave it behind for the day?
Take one spare and some tyre plugs?
Am I being too worried?
What is every ones experience who tow trailers?
Reply By: MEMBER - Darian (SA) - Wednesday, Feb 21, 2007 at 21:08
Been there myself - we have a Campomatic hard floor trailer - when closed, it has the metal rack on top - we carry a used spare case or two (mot wheels) up there, depending on where we are going (not too heavy to lift up and down each day) - with a spare wheel for the car and trailer for starters, we intend to call on these cases at the next service centre that we drift into, should we trash a tyre - just in case we get a second flat, we have some tyre changing/repair gear that we 'might' be able to use at a pinch :-0)
AnswerID: 223245
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 21, 2007 at 21:28
Thanks for that.
I was looking at my CT spare carrier on the draw bar, and it has room to put a 2nd spare there. May do that.
FollowupID: 484105
Reply By: Grandpa joe - Wednesday, Feb 21, 2007 at 21:24
Hey Odd,
I used to have the same deisel as yours in the pic and in my travels, came across a bloke that had bolted a bit of steel bar on to where the fold down rear seats used to be on one side. he then used a ratchet strap to hold it tight to the support.
AnswerID: 223249
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 21, 2007 at 21:42
Thanks,
Sort of thing I was thinking about.
Post and strap sounds easier than making a full bracket.
Good one.
FollowupID: 484109
Follow Up By: Grandpa joe - Wednesday, Feb 21, 2007 at 21:56
How many K's on the on the plod mobile have you got?
FollowupID: 484123
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 21, 2007 at 22:06
280,000k in almost 11 years.
FollowupID: 484127
Reply By: Willem - Wednesday, Feb 21, 2007 at 23:54
Oldplodder
I would have thought that you would carry tyre plugs with you at all times.
I think you worry too much. How often have you had to use your 2nd spare whilst travelling?
AnswerID: 223292
Follow Up By: Member - Oldplodder (QLD) - Thursday, Feb 22, 2007 at 15:54
Good point.
Have only had the occasional flat.
Normally in the middle of no where.
Felt a bit safer nowing I still had another spare to go just in case.
But never used it.
Actually, I most probably have 'loaned' it to more people to get them out of trouble than I have used it.
Yes, I worry too much. I do carry tyre plugs.
FollowupID: 484252
Reply By: meandet - Thursday, Feb 22, 2007 at 08:42
Hi Oldplodder
We have done five big trips now 3 of which were towing our Tvan. Before the first trip, I had a Kaymar carrier installed which gave us an extra spare. With the CT, we have 3 spares, spare tubes, big red compressor and tyrepliers and have used none of it. (we use the big red to re-inflate tyres after lowering them for sand driving). It is so important to drive to the conditions and watch out for sharp pointed rocks on the road. Take it easy and you might not get into any trouble at all.
AnswerID: 223316
Follow Up By: Member - Oldplodder (QLD) - Thursday, Feb 22, 2007 at 15:55
Definitely yes to all that.
Not so easy to fit a rear carrier to the paj when there is already a spare on the back door. :o)
FollowupID: 484254
Reply By: Penguin (NSW) - Thursday, Feb 22, 2007 at 10:30
Hi Oldplodder
You said "....Bit worried about 20 plus kilos of tyre loose in the back behind the safety barrier. "
When I carry my second spare it gets strapped vertically to the cargo barrier. Doesn't take that much room and doesn't go anywhere.
Mike
AnswerID: 223348
Follow Up By: StephenF10 - Thursday, Feb 22, 2007 at 13:14
Same here. I bought a special 3-arm strap and hook setup with a ratchet buckle. It normally sits vertically against the rear of the cargo barrier but I can use the same straps to tie it to a pair of roof bars if I need more space inside.
Stephen.
FollowupID: 484231
Follow Up By: Member - Oldplodder (QLD) - Thursday, Feb 22, 2007 at 15:58
Thanks for the suggestion.
Already have fridge in the rear.
Maybe take out the back seat and strap the tyre to the front of the barrier?
FollowupID: 484258
Follow Up By: Penguin (NSW) - Friday, Feb 23, 2007 at 09:48
Sounds OK. I'd make pretty sure that the straps are substantial though. A 20kg wheel would do quite a bit of damage in a prang!
Mike
FollowupID: 484365
Follow Up By: StephenF10 - Friday, Feb 23, 2007 at 12:17
I always prefer the heavy stuff BEHIND the barrier. If necessary I can fold the rear seats (or take them out) out and move the barrier to the forward position to carry more stuff behind it.
Stephen.
FollowupID: 484383
Reply By: Member - Barry M (NSW) - Thursday, Feb 22, 2007 at 11:18
Same problem, old mate. I reckon I can knock up a wheel carrier under & behind
the axle of the "scroogemobile" C/t. Like you I could fit two on the front but with a
box full of spares & stuff already there I thought under the back would assist
weight distribution. May affect departure angles a bit but not going in the real
rough stuff anyway, hope to make it removable anyway. Tempted to only take 2
spares but my rubber isnt that flash, just too good to replace, if you understand.
I have to get it built shortly so may report in how it goes.....oldbaz.
AnswerID: 223354
Follow Up By: Member - Oldplodder (QLD) - Thursday, Feb 22, 2007 at 15:57
My concern to, too much load on the draw bar with 2 spares and a large box.
I have a water tank under the rear, and could maybe sling the spare under the front of the CT. That water tank in the back does help draw bar weight, i.e. cuts it down when full of water.
FollowupID: 484255
