Nuvi 660 Problem Fix
Submitted: Wednesday, Jan 31, 2007 at 11:35
Member - Doug T (W.A)
If any of you get this problem here is the remedy, Handy to know if needed/
"system software missing"
The Nuvi will not boot!
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
Apparently this sequence will only work with the above error. I hope this assists others if they encounter this problem.
