nuvi 660
Submitted: Tuesday, Jan 23, 2007 at 19:34
ThreadID: 41544 Views:2013 Replies:1 FollowUps:1
just to let you guys know of a potential problem with nuvi 660,current web update jan15 2007 from the garmin website conflicts with mapping installed on the nuvi causing you to loose all your map data.Had to send my nuvi back to gme in Dandenong this arvo for re installation of my map data...copy of email from garmin .."..Sorry for the inconveniences to you
To restore map data, please contact dealer below for map re-installation
GME Electrophone
Unit B 22-24 College St
Gladesville, NSW 2111
Phone: 02 9879 8888"
regards
kev
castlemaine
Reply By: Member - Doug T (W.A) - Tuesday, Jan 23, 2007 at 20:36
When you done the update you should then press the re-set on the back and put it where it can get data from the Sat's and forget it about it for 2 or 3 hours while it sorts itself out then all will be ok , I had the same and did the same , if you want some POI's check mine out.I am always adding more or updating
members.westnet.com.au/dtilley/gps.htm
AnswerID: 217332
Follow Up By: kev 57 - Wednesday, Jan 24, 2007 at 18:04
thanks doug,tried the reset and restore default settings to no avail,both Garmin & GME were not surprised about the loss of map data...sounded like they have been doing quite a few map reloads..
kev
castlemaine
FollowupID: 477974
