Prado water tank
Submitted: Saturday, Dec 09, 2006 at 19:48
ThreadID: 40213 Views:3738 Replies:3 FollowUps:2
Hi guys,
Anybody got a "Long Ranger" water tank fitted to their 120 Prado? How is the fit? Any affect on ground or departure angle? Is it vulnerable to damage? Where does the tap end up? and where is the fill point located?
Thanks in advance.
Mike.
Reply By: Member - 'Lucy' - Saturday, Dec 09, 2006 at 22:48
Nup!
I was under the impression a 'long ranger' was a fuel tank made from 'pickled steel'.
Have you discovered the secret of using water as fuel, if so could let us all in on this discovery.
AnswerID: 209532
Follow Up By: Member - Mike_L (SA) - Saturday, Dec 09, 2006 at 23:13
Didn't I tell you guys? I've managed to make Biodiesel from water.... Just my luck there's a drought on.....
Long Ranger also make water tanks, along with fuel tanks.....
FollowupID: 469573
Reply By: Alan W - Sunday, Dec 10, 2006 at 21:12
Hi Mike,
As the long ranger tucks up between the rear bar and the rear fuel tank, it is very well protected.
The tank is no lower than the bumper, therefore departure angle is unaffected.
As that space is tiny, the tank only holds a lousy 20 ltrs. Consequently I personally couldn't justify the $500 odd bucks for such a little gain. ( 1 less gerry can. ) So I didn't look into it any further to know where the tap or fill points are.
AnswerID: 209660
Follow Up By: Muddy doe (SA) - Sunday, Dec 10, 2006 at 22:30
Yes, had it been 40-50 litres I would be there like a shot but 21 litres was not enough to make me look too long at shelling out that sort of cash.
Muddy
FollowupID: 469697
Reply By: pepper2 - Monday, Dec 11, 2006 at 11:07
You can get a plastic bladderthat is designed to fit in unused space behind internal trim,i have one in LHS rear quarter panel of patrol....takes up no space holds a bit over 20 litres,made in melb avail at 4wd stores etc.cheaper than other tanks
AnswerID: 209722
