Diesel smell in carpet
Submitted: Thursday, Nov 23, 2006 at 21:48
Mullo
Can anyone tell me how to get rid of a diesel spill in carpet? I just purchased an old 60 series cruiser and found that the previous owner had spilt some diesel in the rear carpet, the smell is real bad. Any suggestions would be great.
Reply By: ultimate geoff - Thursday, Nov 23, 2006 at 22:07
Gday Mullo
you can try White spirits, its dry cleaning fluid or refined petrol, you can get it from the hardware, you wil need to lift the carpet first and remove any damaged underfelt, if you dont you wont get rid of the smell, then soak the carpet and scrub it with a white cloth keep turning the cloth untill the cloth stops getting dirty.
you can then use an air blower to help the white spirits evaporate out of the carpet or it will air dry anyway. then replace the felt and you should be right.
I knew having an old man thats a dry cleaner and being a motor trimmer for 30 years would come in handy one day.)
hope this helped
geoff
206604
Follow Up By: ultimate geoff - Thursday, Nov 23, 2006 at 22:10
OR a match:)
466571
Follow Up By: Member - Duncs - Thursday, Nov 23, 2006 at 22:20
A match on its own will not work. For the diesel to burn you would have to heat it first. However if you combine the match and the white spirit success is almost garanteed.
As Geoff has suggested removing the carpet and underfelt from the car is advisable.
Seriously, if you are replacing the underfelt have a talk to the guys at Department of the Interior at Carlton. (Google). They supply a number of products that do the job of underfelt and some do it a lot better than the standard stuff, particularly in relation to heat insulation.
Duncs
466572
Reply By: Tim HJ61 (WA) - Thursday, Nov 23, 2006 at 22:54
If you can find someone that makes BioD, ask them for some by product, or glycerol. They'll give it to you, and get a 20 litre drum while your about it, it won't go astray.
Fantastic oil remover from hands, car parts, clothes and yes, carpets. Despite being virtually black and not smelling the greatest, I used it on a bedroom carpet that my 16 year old had trodden some oil onto. Poured a bit on a rag and wiped it on, then poured the Glycerol onto the carpet, scrubbed it a bit, rinsed it off and bingo, new carpet.
Also great for oil stains on driveways, anything that is oil based. AND it's biodegradable.
So for the 60, I'd suggest pulling the carpet out so you can dry it out better afterwards, splash the Glyercol on, then a bit more, scrub it around rinse it off, let it dry and tell me if it smells. It won't do any harm, but don't leave it neat on car paintwork....
Tim
206619
Follow Up By: Member - Mary W (VIC) - Saturday, Nov 25, 2006 at 11:12
Are you able to buy glycerol from any place like bunnings etc -need something to shift some come oil stains? Thanks,Mary
466795
Follow Up By: Tim HJ61 (WA) - Saturday, Nov 25, 2006 at 15:11
Hi Mary,
Not that I know of. If you can find someone local that makes BioD at
home, they will give it to you, happy to get rid of it.
It's the same basic stuff that is used for soaps and face creams, but BioD glycerol is black and smells a bit. So it's consigned to a waste product unfortunately. However it still functions the same as the clear glycerol/glycerine.
Maybe someone local to you and on this
forum will get in touch with you to offer some to you. I'm in
Perth and spoke to a guy with 400l of the stuff that he'd be happy to get rid of.
Tim
466825
Reply By: Member - Julie P (VIC) - Sunday, Nov 26, 2006 at 17:01
G'day - had a problem with diesel spill myself once - all over me as
well as in the car - cleanied it up the best I could - then used about 3 packets of bicarb soda - sprinkled all over DRY carpet etc - and just leave it there for a few days - vac it out when you need to - bicarb will get smells out of just about anything - as
well as being a great cleaner dissolved in water to clean fridges, sinks,
toilets etc - you name it and bicarb or white vinegar can clean it -
but bicarb left in any material - carpet, clothing even your dog or cat - will remove smells - I always leave some in the camping fridge when not in use as
well as in the house fridge if we go away. good luck
jules
206967
