Caravan TV Antenna Advice
Submitted: Tuesday, Oct 31, 2006 at 20:13
ThreadID: 39013 Views:33527 Replies:7 FollowUps:4
Have just purchased our first van and need to get a TV antenna. What are the do's and don'ts? We do not want a weinguard due to cost.
Also we don't need particualrly good reception as we are only interested in using it in major cities.
Reply By: Mr Fawlty - Tuesday, Oct 31, 2006 at 20:25
Any of the available ones will do the trick. May be an advantage that the one you buy can be used with an amplifier but do ensure that it can be mounted for either vertical or horizontal signal polarity....
The winegard is a good antenna untill you find yourself somewhere that still uses vertical polarity.
As UHF TV signals are now the norm you just have to make sure you are in line of sight of the transmitter to get the best reception, a wet tree or a large building in front of your antenna will play havoc with your reception....Don't be conned into thinking that the most expensive is any better than the cheapest, you should compare specs though these at times can be a tad speculative....
tricky dicks & bunnings had some "Portable ones" last time I looked.
I'm not sure of the performance of the omnidirectional ones but one of the affianados will no doubt reply with results.
AnswerID: 202143
Reply By: japmel - Tuesday, Oct 31, 2006 at 21:01
Pajeroman,
I use Digimatch Explorer Caravan TV Antenna from Dick Smiths part number L4024 combined with a Kingray MHW34FS Mast Head amplifier.
So far so good.
But keep an eye on this Forum as Derek from ABR has got some TV Aerials and Boosters coming from Hong Kong that may be the new must have item for Caravans.
AnswerID: 202152
Follow Up By: japmel - Tuesday, Oct 31, 2006 at 21:18
Should add that the Didimatch does both polarities (Virtical & Horizontal)
FollowupID: 461638
Follow Up By: japmel - Tuesday, Oct 31, 2006 at 21:19
Another case of brain working quicker than fingers. That should be Digimatch
FollowupID: 461639
Reply By: T-Ribby - Tuesday, Oct 31, 2006 at 21:06
I have a Happy Wanderer original T-bar aerial which works fine, and better with the booster providing you're on 240v. All up cost around $150. Here's the link
www.happywanderer.net.au/
T-Rib
AnswerID: 202156
Reply By: Member - Athol (NSW, 2527) - Tuesday, Oct 31, 2006 at 21:08
Ahh the bain off my holiday life!!!!
We have just returned from 8 weeks around W.A. We have a yagi antenna from Dick Smiths $70, It can be used both vertical and horizontally. Most places it was ok with a bit of trial and error. But after talking to people I don't think there is such a thing as the all-rounder.
Currently looking at the pro's and con's of Satellite, but is the expense worth what's on the useless box. (other than the news)
Athol
AnswerID: 202157
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Tuesday, Oct 31, 2006 at 21:34
Paj/man if you like you to can puchase a cheap digital set top box will give you better reception also.More on thie if you go to Around -Oz.com they have done long yards on testing these things & many others once you are on their site just follow the links they also own the site.The campervan & motor home site also has some stuff also.
Cheer's bob.
AnswerID: 202165
Reply By: SunWizard - Wednesday, Nov 01, 2006 at 10:09
Caravan forum has plenty information caravan TV aerials and extension poles and stuff. We use a Digmatch Explorer because it is the only aerial that does all channels in Australia in both vertical and horizontal. Bought the Digimatch Explorer from Jaycar
AnswerID: 202248
Reply By: Member - Steven H (ACT) - Wednesday, Nov 01, 2006 at 18:29
I have just finished my research on TV antennas and have decided upon a Digimatch from DSE at $69 plus a MHW34FS and a PSK12F power supply. I still havent worked out an effective way of placing a mast onto our pop up Goldstream, need something than can be adjusted from ground level and it will have to be mounted on the side of the roof.
AnswerID: 202332
Follow Up By: wazzaaaa - Wednesday, Nov 01, 2006 at 21:56
I too looked at the Digimatch but it was only 11db on uhf and did not do it for us at teewah camping area
Wazza
FollowupID: 461894
Follow Up By: Member - Steven H (ACT) - Wednesday, Nov 01, 2006 at 22:09
So can i ask what type did you get?
FollowupID: 461897
