clutch shudder
Submitted: Tuesday, Oct 31, 2006 at 00:23
lost
hi ya all. just wanting to know if any other owners of 78/79/105 series cruisers have had dramas with clutch shudder, even after getting the clutched changed.
i got my clutch changed last week, and its been shuddering(when taking off or reversing) ever since.
i took it back 2 the mechanics who contacted Toyota(genuine Toyota clutch fitted), Toyota said its 2 do with the injector pump, the stroke has 2 be set to its longest stroke which will repair/restrict clutch shudder.
has any1 heard of this story????
i chased up Toyota about it, they gave me a copy of a bulletin that was sent to all Toyota dealers regarding it.
i have spoken to 2 diesel injection workshops regarding it and they both have heard story's going around about the problem but have never come across it and also think its crap that the pump will make it shudder.
any answers will help
thanks
lost
Reply By: Member - 'Lucy' - Tuesday, Oct 31, 2006 at 09:56
Here is another angle to consider as
well LOST.
I have had a Datsun B-Bird Station Wagon since new (1981 series I purchased in Apr 82)
From day one that 'mother of all mothers' had a clutch shudder plus gear box front end oil leak amongst a whole host of other things that continually 'happened'.
Only 12/12 warranty in those days so I was flying solo in the fix-it-up game almost instantly.
Anyway 7 clutch plate kits later at 165,000kms and an original engine recondition I decided to have the engine balanced as
So, the people doing the re-con asked me to supply the new clutch kit and flywheel to be mounted to the motor prior to the 'balancing' as that is what you do apparently to get a properly balanced drive line. ( Told this and have no idea if it is correct or not)
So I drop it off and later get a phone call informing me that the Flywheel has 'hard spots' and needs machining (?????????????) OK! go ahead.
When I pick it all up I question the chit out of them about the 'hard spots and machining'.
Apparently flywheels develop these hard spots for various reasons and once they get them, then the noticeable effect is the 'shudder' you are complaining about.
Since then I have changed a number of clutches on different vehicles and ALWAYS get the flywheel 'machined' off. Never had a problem since with shudder in the clutch after a clutch change.
The other thing that the re-con guys explained to me was that it doesn't take much to cause the said 'hard spots'
Ah!
well its something else for you to ponder on for the day, if nothing else.
202005
Follow Up By: lost - Tuesday, Oct 31, 2006 at 12:35
yep, i got the flywheel machined when the clutch got done, as it gets hot spots, and heat cracks in them. thanks
461508
Follow Up By: Member - 'Lucy' - Tuesday, Oct 31, 2006 at 15:34
Well! in view of that I am all 'clutched out' of ideas.
Maybe a heavy duty after market clutch kit might give you a bit more joy.
I am grasping at straws here LOST.
461547
Reply By: atoyot - Tuesday, Oct 31, 2006 at 22:01
Yep, I got the story about the injector stroke timing as
well. I reluctantly let them adjust it, and first time, the thing ran like a dog and still shuddered. When I took it back, they said the mechanic stuffed up the settings and did it again. Buugger me, this time, for the first few weeks, I could not get it to shudder at all. Then, a few weeks later, shudder came back and the thing just got slower and slower, thirstier and blew heaps of smoke. I asked them to put things back to factory specs (checked by pump specialist) now it still blows a bit of smoke, doesn't go as
well as it used to, and used a bit more fuel. Still shudders, but mainly noticed when cold. One other thing it does it that it surges on a medium throttle on light hills at about 1600rpm. Back off a bit or plant it, and the surging stops. When I say surging, sort of a roo hop at speed (50kph).
The story I got was the pump was preset for Japan (altitude??) and that the adjustment had been found to fix some. Didn't fix
mine. I personally wouldn't let them touch the pump, but then again, I have since lost trust in the local dealer (didn't find a broken rear shock in a major service - that's another story though.)
It's something that I believe can be fixed with certain HD clutch types and machining and balancing etc, but I havn't bothered yet; I sort of learned to live with it.
Andrew
202179
