Inverters (and yes, I've performed a search)
Submitted: Thursday, Mar 13, 2003 at 14:37
ThreadID: 3829 Views:2293 Replies:9 FollowUps:8
There seems to be lot of discussions and info on inverters here, and in the archives, but a few questions haven't been asked/answered. Maybe I'm the only one that doesn't know these things. Can someone enlighten me, please?
When using an inverter, is the current draw on the battery equal to the inverter's potential output, or only what the inverter is driving? For example, if a 300 watt inverter is driving a 100 watt appliance, is the current draw on the battery 300/12 = 25 amps per hour or 100/12 = 8.3 amps per hour?
Can the inverter and appliance be run with the vehicle engine running? If so, and if the alternator was pumping, say, 35 watts back into the battery, the above example would result in a zero net draw from the battery? Yes?
Can an inverter be hooked up directly to an alternator, with appropriate solanoid/regulator, and be used to run appliances/charge batteries while driving the vehicle?
