Ticking noise in Troopie 78 turbo
Submitted: Monday, Jun 26, 2006 at 11:58
Member - Keith B (QLD)
This car (Oct 2005 build) has travelled just 9000km and I have noticed a ticking noise a bit like a poorly adjusted valve when the engine is under load. Local dealer says this was typical of the previous model and is checking with Toyota in Japan (!) to see if it is the same with this model. Seems odd to me.
Any comments?
Reply By: Geoff (Newcastle, NSW) - Monday, Jun 26, 2006 at 12:50
Hello Keith,
I've got a Feb 2006 build of the same vehicle that is right now having its 10,000k service.
To my knowledge it doesn't make a ticking sound. I'll have a specific listen this afternoon when I pick it up.
Actually, I've just asked the guy I work with who's dad owns a 2005 wagon with the same engine and he says it doesn't tick either.
Geoff.
| Geoff,
Landcruiser HDJ78,
180398
Reply By: zam045 - Monday, Jun 26, 2006 at 13:34
I had a similar problem on my 2.8D Hilux and it only seemed to do this under load.
Thje problem turned out to be the exhaust manifold, a couple of the stud had broken, so got this drilled and replaced with a new gasket and haven't had a problem since.
180411
Reply By: Martyn (WA) - Monday, Jun 26, 2006 at 14:50
Keith,
Ticking noise under load normal, not to sure about that comment, usually indicates a litle end / big end or valve train problem depend on the relationship between the ticking noise and the engine speed, half engine speed or running speed. So if it's normal he would know what the noise is and wouldn't have to
check with Toyota. Could be a high pressure gas noise on the exhaust side, gasket or something like that. very hard to diagnose without hearing the noise.
I would pursue the answer with only 9k on the clock, if it dosn't sound normal to you and it seems to others on this
forum that this is abnormal, nuff said.
My opinions etc etc.....
180419
Reply By: Member - Phil G (SA) - Monday, Jun 26, 2006 at 17:32
Hi Keith,
I'd expect the dealer might at least
check the valve clearances. Its a different system to most these days - with SOHC and 4 valves per cyl, each rocker activates two valves via a
bridge arrangement, and it is adjustable - its not a shim system.
Mine is the same motor with 95k on the clock - ticks occasionally when cold or if it hasn't been used much. Becomes tick-free after a trip. The tick sounds like its coming from the injection pump. My valve clearances are fine.
phil
180449
Follow Up By: Member - Phil G (SA) - Monday, Jun 26, 2006 at 17:36
Just as an aside, Keith, these motors can develop some EGR valve malfunctioning over time, and then they recirculate more gas than the should which fills up the intake manifold with carbon and the cat converter can clog up.
Mine had this problem, and since I've cleaned out the carbon and fixed the EGR Valve so it won't open again, the motor's running better and fuel consumption has improved back to what it should be.
LCOOL site has info on this.
phil
436685
Reply By: cabbageoz - Monday, Jun 26, 2006 at 23:56
I know this sounds stupid but what do you do when you come to a tick
gate
180523
Reply By: dock - Friday, Jun 30, 2006 at 07:29
Keith, This might be a long shot but had a similar problem in my 78 troopy. Found that the drain pipe on the bottom of the heater air intake (under the dash on the passemger side) had been kicked off allowing the noise of the motor to come through the firewall. Sounds like a ticking noise the faster the vehicle goes. Not sure if this is your problem but only takes 5 seconds to
check
Cheers Dock
181140
