Help with, Toyota Fj73 SWB
Submitted: Friday, Jun 23, 2006 at 16:16
ThreadID: 35217 Views:6171 Replies:5 FollowUps:7
Have just looked over a Toyota Fj73 SWB, 3F engine 5 speed Manuel with Duel battery’s, A/C, rear Axillary Power plugs in the back + Inverter, with a friend from work, he wants it Just for 4Wding
They are Asking is $4400 in WA with Warranty and will not move on the price we have tried.
It has 298,000K on it and is in visually good conation inside and out, how good are these engines?, It puffed a bit of smoke on start up but then ran clean.
Problems I can see are> Rear Main seal
Front Crankshaft seal.
Possible Front Axle seals> Drops of what appeared to be Diff oil on the bottom inside of the tyre and around like wheel bearing, Hub sorter area past the CV’s
And possible Transfer or gearbox oil leak, Location or cause I am not sure of.
What other things should I be looking for (Will check the 4WD system tomorrow on the test drive) what hidden problems may I of not seen and should I look for tomorrow as I am not that Knowable with the Toyo stuff.
1Rear main> A PITA but he can live with it as long as it isn’t too bad; We Don’t really what to drop the G/Box to fix it> Might try for warranty.
2.Front seal> No Problems we will just replace the seal
3.Axle seals> what is the go hear, How hard are these to do and any other damage that they may have caused, Warranty agene Maybe.
4. Gear box/TCase, any thoughts about where the leak could be> I can’t seem to pin point it.
Thanks People
