Oziexplorer to FX324
Submitted: Thursday, Jun 22, 2006 at 08:05
Member - Nutter (QLD)
Wondering if anyone can help me , I'm am trying to download waypoints from Oziexplorer version 3.95.4i to a Magellam FX 324 Colour, has anyone done this succsessfully if so I'm wondering if you may be able to give me a few tips. Have changed config settings to the best of my knowledge, also done a
forum search nothing there on this particular problem. Any help will be greatlt appreciated.
Guy
Reply By: signman - Thursday, Jun 22, 2006 at 08:58
Hi there
If you have the GPS set up correctly in the 'configuration' section- it is a simple thing to 'Send waypoints to GPS" ..
Is the Magellan FX 324 an option in the Configuration set up??
179814
Follow Up By: Member - Nutter (QLD) - Thursday, Jun 22, 2006 at 09:01
Hi Signman, no the FX 324 isn't a config set up option.
435998
Reply By: signman - Thursday, Jun 22, 2006 at 09:05
Aha...is it the latest version of OziExplorer??? Might be worth an email to Des at OziExplorer to see if another Magellan 'model' on config. would work for you!!
179816
Follow Up By: Member - Nutter (QLD) - Thursday, Jun 22, 2006 at 09:54
Will do, thanks for your help.
See ya
Guy
436012
Reply By: Sand Man (SA) - Thursday, Jun 22, 2006 at 17:55
There is an option in the configuration to set the GPS type to "other Magellans", if yours is not listed.
Does it work the other way?
Can you communicate from the GPS to the Laptop or PC that is running OziExplorer.
It may be you need to adjust the coms settings. (baud rate, com port, etc.)
179920
Follow Up By: Member - Nutter (QLD) - Monday, Jun 26, 2006 at 08:23
Hi Signman, have a reply from Allam one of the techo guys from oziexplorer, tells me to try setting the GPS setting in config to MLR / other MLR as they believe the FX 324 uses this gps engine, I would have never stumbled onto that one. I haven't tried it yet, fingers crossed.
See ya
Guy
436601
