100 series TD cranking battery
Submitted: Wednesday, Jun 21, 2006 at 17:30
ThreadID: 35154 Views:5510 Replies:9 FollowUps:0
as we are aware the 100 TD has two batteries as standard.
who has replaced one of the batteries dedicated as cranking and supply for the engine/car only.....(all other electrics as well of course) and replaced the other to use a 2nd for fridge etc etc ...
have you had any problems ...especially with starting
how long has it been since being done
what size did you fit
any other info
Reply By: 100TD - Wednesday, Jun 21, 2006 at 17:41
1,i was told by toyota warranty would be void if any related problems arose due to only one crank battery regardless of capacity?so i stayed safe and installed 3rd tray with gel cell to drive fridge etc and replaced both mains with optimas and in 3 years no problems.cheers Paul
AnswerID: 179703
Reply By: Phil - Wednesday, Jun 21, 2006 at 18:19
I have split my batteries with OL dual battery system , put in athe largest cranking Battery I could get , works fine
AnswerID: 179718
Reply By: Member - Ivan (ACT) - Wednesday, Jun 21, 2006 at 18:44
Mate of mine did this a couple of years ago and still going fine..
Ivan
2008 D4D Prado
AnswerID: 179723
Reply By: Member - Jeff M (WA) - Wednesday, Jun 21, 2006 at 18:50
Obviously the surf is a little different to the 100 series, however the 3.0LTD's came standard with two cranking batteries. I split the batteries and put a 700CCA overlander as the start and it works great. (better than the other two crappy ones).
AnswerID: 179725
Reply By: SMMKJD - Wednesday, Jun 21, 2006 at 19:36
I have a 2003 TD 100 series and the second change made was to separate the batteries with a Redarc and ran this setup with the standard batteries for 12 months. Since changed to a 600 or 700 cca starting battery and a 600cca marine accessories battery, both from Century.
Many trips and never a problem - run usual bits, compressor, Engle, UHF, lights etc...
Note that if a sparkie does the work it may be same cost to go to ARB and fit 3rd battery tray & kit (fitted the tray but compressor sits in it).
Steve
Adelaide
AnswerID: 179743
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, Jun 21, 2006 at 19:40
HI # 1
No problem with the set up. The factory batteries are quite small and one replaced a with decent ones and a Redarc or ABR isolator fitted there is no problem.
I am currently designing the 3rd battery and fuel filter assembly for the LC and should be ready soon.
Regards Derek.
AnswerID: 179746
Reply By: Flash - Wednesday, Jun 21, 2006 at 21:38
Did it on my mates 100 series and works a treat. Went for a big N70zz cranking batt and it starts the engine without a wimper. He has an deep cycle AGM wired up in the second battery position which works perfectly as his camping battery.
I personally cannot see the point in fitting a third battery.
(Standard cruiser batteries are about the same as a Falcon battery.)
AnswerID: 179769
Reply By: Member - Phil G (SA) - Wednesday, Jun 21, 2006 at 22:25
78/79 series with the (almost) same 1HD-FTE engine use a single N70 size battery. Mine starts fine at zero degrees.
AnswerID: 179782
Reply By: Trekkie (Member - WA) - Wednesday, Jun 21, 2006 at 23:27
Member No 1, I put a Rotronics system in shortly after I purchased my 100 Series TD. I replaced the OE batteries 18 months ago with Champion/Exide Extreme 620CCA12V N70EXL for cranking and Champion/Exide Endurance 12V 75A/H ED5 for auxillary. ($125/$135) I never really had any problems with the OE and no problems with the replacements.
AnswerID: 179795
