Friday, Jun 09, 2006 at 08:27
Not overly sensitive but do require correct voltage ,, you must remember that the
waeco system is essentialy designed to run best at 24v,,the bd 35 and bd50 will tolerate 12v but anything less and problems begin ,,also have you checked the "cooling power "switch setting ? economy =2000rpm ,normal=2500rpm,high=3000rpm and using turbo =3500rpm ,,
the only time we have ever had the error light flash is when had the setting on high and the
battery was run down to 11.8v ,,,
acording to the
Waeco handbook testing for voltage drop must be done while the unit is under load ,,
433718
