100 series shuddering rear
Submitted: Monday, Jun 05, 2006 at 12:54
ThreadID: 34629 Views:1654 Replies:2 FollowUps:0
I posted a query back in April regarding a shudder when braking that didn't appear to come from either the front or rear end. I had some helpful suggestions regarding brakes and brake maintenance etc. After a couple of trips to Brighton Toyota the best I had achieved newly machined front discs and replaced front pads but still the problem occured. I then went to a brake specialist who said straight away not brakes, it must be drivetrain related.
After a bit of diagnosis Lane Toyota has identified the problem as the auto transmission torque converter failing to release as you slow down, causing the engine to mimic a stalling characteristic. The cause is a washer made from a "bakerlite" type substance wearing at a slower rate to the metal housing. It sounds as though this is a problem being more frequently seen in recent times. Toyota are apparently inconsistent in their approach to whether this is a problem that should be covered under warranty when the warranty period has expired. My 'cruiser is 2001 Turbo Diesel with 130000 on the clock. We are now waiting to see whether Toyota will asssist with funding the $1300 repair job.
Reply By: Member - Nick (Kununurra) - Monday, Jun 05, 2006 at 13:25
Good luck with it.Of coarse it should be a warranty issue BUT!!!
AnswerID: 176807
Reply By: 100TD - Monday, Jun 05, 2006 at 17:25
hi Big Bird,keep us posted on the results as i have a TD auto also(03 model)that has just run out of warranty.havnt had any issues with it to speak of so far and hopefully never do.cheers Paul
AnswerID: 176862
