Tanami Tourer replacement poles
Submitted: Tuesday, May 30, 2006 at 12:36
Grumpy in WA
Hi everyone,
I hope someone can help me out here, when we moved from
Sydney to
Perth, (along with many other things that I don’t want to think about) our tent poles for our Tanami Tour tent never made it, thanks to the disgraceful service from Kent Moving. (take note anyone considering moving soon)
By doing an Internet search I found the following product from discount camping: Internal Side Frame
Internal Side Frame - 3 Metre Wide, The internal side frame replaces the centre pole of a 3m wide touring tent, has 2 adjustable legs that run alongside the walls.
Does anyone know if this completely replaces the old centre pole or does it need some of the parts from the existing pole?
If it will work then I can have a functioning tent back fairly cheaply and now without a centre pole.
Reply By: Shaker - Tuesday, May 30, 2006 at 13:22
In the COI tents, it replaces the centre pole, I would imagine that it would be the same for all, otherwise what's the point in them?
175632
Follow Up By: Grumpy in WA - Tuesday, May 30, 2006 at 15:04
I am not sure if is uses some of the existing top section, that why I asked the question..
431713
Follow Up By: Shaker - Tuesday, May 30, 2006 at 15:56
It does use the existing top section.
431722
Reply By: Sand Man (SA) - Tuesday, May 30, 2006 at 15:58
Grumpy,
Only way to be sure is to ring them up.
I'm sure they would be only too happy to help with advice.
(08) 8262 3399
No connection.....etc...etc.
175645
