ccruise control ?
Submitted: Thursday, May 18, 2006 at 18:57
handy
just got the AP60 to fit to my gq td42 and a bit confused where to connect the
vacum from the actuator to. Any help would be great. 92 model. cheers
Reply By: RedGibber - Thursday, May 18, 2006 at 19:49
Hi handy,
not sure about the vacuum plumbing in a 92 GQ (I have an AP160 fitted to my GU TD42T), but trace the output from your vacuum pump. Should end up feeding a canister/reservoir or similar. Out of said canister there should be feeds to the brake and clutch servo units. In my case, I spliced a T-piece into the feed to the clutch servo - works a treat!
In my GU, the canisters (there are 2) are located on the passenger side near, but not on, the firewall (which is where I located the cruise control actuator).
Hope this helps...
RedGibber
173399
Reply By: Flash - Thursday, May 18, 2006 at 21:13
I Teed
mine into the vacuum tube feeding the power assisted clutch, line to the power brakes would be Ok too.
92 GQ will have vacuum pump on back of the alternator, and may or may not have power assist on the clutch depending on model.
Hope that helps,
173423
Reply By: Member - Jiarna (NT) - Thursday, May 18, 2006 at 21:17
I fitted this cruise control to my LC 80 series, and plumbed the vacuum line onto the brake booster hose. Works a treat and has had no discernable effect on the brake booster
173425
Follow Up By: J.T. - Thursday, May 18, 2006 at 22:36
Just curious?Who sells these cruise controls and do they work
well?Any effect on fuel economy?
429385
Follow Up By: V8 Troopie - Thursday, May 18, 2006 at 23:43
I got the AP50 from K-mart when it was on special.
Yes it works
well, even in my manual car, though it won't change gears in that case;-)
Economy is worse if I leave it on when the road gets into hilly terrain and I'm too lazy to shift down - the 6.2 Chevvie has enough grunt to climb some hills in fifth gear.
Economy should be fine with an automatic gearbox.
The reason I got the gadget is to be able to relax the right foot from time to time to avoid knee cramps. The troopy's driving position is not the most ergonomical for long distance driving.
Klaus
429393
Follow Up By: handy - Friday, May 19, 2006 at 07:40
i got
mine from super cheap $189. i got it for the same reason as v8 troopie
thanks for the replys
429423
