Wednesday, May 17, 2006 at 13:25
Cipher
You should get plenty of input on this topic from the OZ gang so be warned.
If you are heavily into the dirty stuff and are forever going
places where no man fears to tread, I would probably reccomend the air lockers. Front first and rear if you still have the readies. However they are expensive by the time the compressor is setup and in real terms there seems to be no definitive proof that they are superior to the Auto lockers except perhaps in the extremes of competion or hairy chested off road hero stuff.
I installed auto "Lokka"'s in the front of my 75 series which is also part time, same as yors, as I sometimes found myself in situations you describe which could have been avoided with more traction before the vehicle ran out of puff.
As I was buying a winch at the time, the Lokka's were on special inclusive with the X9 winch, from the supplier which made them a pretty affordable extra for the Tojo. From memory the buy price was $499 - not fitted which was an extra $200 by a diff centre down the road.
I have read all the different opinions on both and with the experience gained from my own set up, can not really see why you would bother spending the extra dollars for air lockers on a "recreational" off roader, unlees of course you were after the little glowing switch as another gadjet for the dashboard..
Their auto lokka operation is quiet and in real terms, I can not hear them engaging or disengaging.
They are not an issue at all on the open road as the front hubs are obviously unlocked so the front diff is having a rest so to speak.
When in use in the soft stuff they have proved invaluable with only a slight tendancy to steer straight, unlike the air lockers which will really push straight in those conditions. This in my opinion is an absolute plus for the auto lockers as you simply wander along windy tracks with the locker engaging - disengaging as is neccessary.
The air locker has to be manually locked in and out as you come to the soft bits and the windy beach tracks I describe above are more the norm than the exception.
Still there are plenty here who will disagree - so good luck sorting it out.
However IMHO, the auto is easily the most cost effective and certainly does it for me.
Have Fun
428959
