Friday, May 05, 2006 at 21:29
Not sure if you have been there before Keith...
Don't leave the canoe at
home though. There are plenty of
places to use it around on the Cooper at
Innamincka.
The road out from
Innamincka is in good nick at the moment but
check the depth of the causeway. If the Cooper is on the rise you will need to carry enough fuel to go around the long way via
the Dig Tree just in case you can't get back thru the causeway.
Good stops on the way out at Scrubby
Camp and
Kudriemitchie Outstation. There were a few camped there as Kudriemitchie is the last place where you can have a fire (banned at Coongie) Facilities there are pretty good as it's looked after by a 4WD Club (Landcruiser I think...) On a
water hole but I wouldn't swim there at present.
The road is a little windy around here but no problem as the speed limit is only 40 anyway.
Once out at the Lake itself there are 2 main camping areas. The first is 4wd only across some sand hills. No prob in the Patrol but I wasn't keen on taking the trailer in there. The camping is more protected but a looonnnng way from the water. Great
views from some of the taller dunes towards the end of the track and we spent quite some time out there watching dingoes and
brolgas at different times of the day.
The other
camping area is close to the
day use area and are little sandy areas backing onto the Creek not far from where it empties into the Lake. There was no-one else there for the 2 days we were there (which I felt was enough time) Remember no fires, no water, a long drop dunny (with a view).
Easy walk down to the lake shore to watch the birds and collect some pipis (mussels if you like...)
Sensational place and worth the trip. And get up early and watch the sunrise. You won't regret it...
426463
