Monday, Feb 17, 2003 at 14:59
I agree with Melissa - always take up the slack before the towing vehicle actually attempts to tow out/take a run at it. You only use the "give it the bootful" method only if all else fails and you don't have or can't be bothered using a winch..... and everyone is happy with any damage being the involved parties own risk.....
MAKE SURE EVERYONE IS
WELL AWAY if you use the "give it a bootful" method - even the person who should have been spotting and communicating between the cars to this point.
I don't like using CB or one/two honks method for this. CB takes at least one hand off the wheel unless you have handsfree - suprisingly really cheap ones like Digitalk can - which makes them perfect for club work. And people may get confused about the number of honks (or in some cases other people feel it's "funny" to hit their own horns if this method is used).
Unless it is likely the car that is bogged is going to make it's situation worse (eg by tipping over further/rolling or digging in deeper) - any strain that can be taken off a cable or winch by "assisting" the pull by engine power should be used, but of course - slowly and carefully - like 1st or second gear low like suggested by Melissa. Obviously the assesment of potenital risk here is the key - not just on making it worse as far as bogging but also damage to engine - if halfway over or in mud etc.....
"Charging" with Snatch Straps is why they break early (see comments about 10 pulls max - pure BS to force people to buy unnecessary new recovery equipment), why shackles break, how bullbars/towbars get torn off and how chassis rails get bent.
Melissa - I can't see how say a 3 Ton rated hook is in any way better than 3 Ton rated shackles or even a (usually 3 Ton rated on a big 4wd) tow bar on this one though - only backing you 80% lol - you usually get my full support. The only benefit may be the attatchment of the hook over the standard tack welded loop - but the towbar is normally held on by far more than 2 bolts....
As an interesting example of these misconceptions:-
I have pulled heaps of people out using standard 16mm "non rated" trailer style (not 4wd style) D Shackles and snatch straps with never an issue with this approach (no failures and never a broken recovery item) - before more and more people started using the "buy expensive gear and bulldoze" method that is tought by ARB/TJM and extreme sport type videos (cos it looks good).
An example - one of these people after stupidly spending their hard earned (
well actually he's got no money and no job - so it really was a stretch for him) on 4.5T rated "ARB" shackles and 12000kg snatch strap (for a 700 kg LJ80 of all things! - Why pay for a 12 Ton rated strap?????) then refused to let me use the trusty 16mm ones that have saved not only their and my ass but much heavier shorty Landcruisers and Patrols time and again to pull my Vitara out (I had my 205/75 All Terrain (Streets) on at the time - hence the bogging)). I think he was just proving how much "better" his stuff was than
mine.....
Strangely my 16mm D Shackles are still legal to hold a 3 ton trailer in the event of a towball breakage! Yet this (and other) f$^%heads was still using the standard bent steel loop (of maybe 12mm max on most Suzuki models) recovery point that is only spot welded to their chassis!!!!! This has a breaking strain of
well below the 16mm shackle......
To appease such people I've since bought a set each of "proper" ARB 3.25 and 4.5 Ton shackles and am using the 16mm ones on a 3 Ton engine crane instead (just in case I need to pick up 3 whole Vitaras/4 Sierras on the one chain simultaneously!).
Strangely ARB/TJM etc are not afraid to try and con people (INCLUDING many 4wd instructors who then pass it on to us and the friends above in particular) into using techniques that guarantee eventual failure of even expensive top-end equipment - regardless it's rating.
What it comes down to with recovery gear is a bit of mechanical sympathy and a little bit of understandings of the laws of physics.
PS - If I see one more bleep who believes it's unsafe to use a 16-20mm thick piece of metal (rated or unrated) to hold a strap on or join 2 straps together but thinks it's ok to use a small piece of broken stick to join 2 straps together I'm gonna make him shield every other person present from the resultant broken stick shrapnel (read arrows) by making him hug the join!!!!
Anyone remember the Battle of Crecy??? "Harmless" pieces of wood are capable of piercing ARMOUR PLATE! i've seen bruises, fractures and busted toughened glass but luckily no serious injuries from this madness - yet.
Andrew
7805
