How to keep warm in camper trailer in winter?
Submitted: Friday, Apr 28, 2006 at 16:05
ThreadID: 33328 Views:15914 Replies:20 FollowUps:32
I'm looking to buy a camper trailer in the near future, to travel through the centre in Winter. How do you best keep warm in a camper trailer, as it seems a bit hard to "re-enforce the walls" in the sleeping area. I find sleeping bags very restricting. Are doonas the only way, or are there any tricks?
Any thoughts welcomed!
Rainer
Reply By: Witchdoctor - Friday, Apr 28, 2006 at 16:20
We have found that polar fleece material instead of a doona really works well. Have camped many times when the temp was well into the minus, with no problems except getting out of bed. Also the canvas holds the body heat in.
Dave
AnswerID: 169506
Follow Up By: Member - Crazy Dog (QLD) - Friday, Apr 28, 2006 at 17:25
Nah Nah Nah - Dutch ovens are the go!
Grrr!!!
FollowupID: 424849
Follow Up By: Member - Bruce and Anne - Friday, Apr 28, 2006 at 20:33
Dave I would have thought a good woman would have been your first recommendation.
Cheers Bruce
FollowupID: 424892
Reply By: rainer - Friday, Apr 28, 2006 at 16:34
Thanks for that Witchdoctor!
I just had a quick look around and the biggest one I could find was 150x130 cm. Do you know a place, that sells bigger ones?
Rainer
AnswerID: 169511
Follow Up By: Member - Omaroo (NSW) - Friday, Apr 28, 2006 at 17:29
Go to a material shop (like Lincraft) and buy it off the roll by the meter. If it isn't wide enough - sew two strips together down the middle!
FollowupID: 424850
Reply By: hopscotch - Friday, Apr 28, 2006 at 16:59
Hi Rainer,
This has been the subject of much discussion on another forum and while the chat has centred on heaters etc the one BIG suggestion made - and I agree - a good beanie for the head. A wool underlay under the bottome sheet helps no end and we even place newspapers under the mattress when there is frost outside.
We use the Mink blankets which are light but very cosy.
Kevin J
AnswerID: 169519
Reply By: Member - Oldplodder (QLD) - Friday, Apr 28, 2006 at 17:02
Good queen sized double sleeping bag rated to -5, and of course some one to cuddle :-))
Other purpose of the 'other' is to warm the bag before you get in.
We toss a coin to see who looses and gets in first on a cold night.
Coldest I have camped is -15 deg C at about 2000 metres, and great with another sleeping bag over, we have a spare sleeping bag we take to throw over on really cold nights, doona or blanket would do.
And a blanket under too helps a lot. Mattresses can be cold things, being just a big pocket of air, whether spring, foam or blow up. Foam may be warmer, but hot in summer.
Oh, and try and keep warm until you get to bed, and not too much alcohol, unless you get to blotto.
And this from a Queenslander, where are those southern suggestions?
AnswerID: 169521
Follow Up By: Members-Neil & Margie-Cairns - Friday, Apr 28, 2006 at 19:05
Hey Oldplodder ,
-15 ,, what frame if mind were you in ,, thats when you either stay home infront of a BIG heater ,, or head north ,, -15 and a Queenslander , just don't add up mate ,, all the best ,
Neil ..
FollowupID: 424867
Follow Up By: Member - Oldplodder (QLD) - Friday, Apr 28, 2006 at 19:50
-15 deg. and 2000m up in Andorra on the Spanish/French border in a Kombi.
Lovely place, great view after you scraped the ice off the inside of the windows in the morning!
FollowupID: 424881
Follow Up By: Member - Julie P (VIC) - Saturday, Apr 29, 2006 at 15:40
We just bought one of those "egg carton" foam underlays - terrific - we also have a rubber backed camp blanket which we put on top with the rubber side up - stops the cold coming down through the top fo the blanket (or doona/sleeping bag - whichever -) - hot water bottle is good - and if you have a soft floor camper a bit of marine carpet - available from bunnings etc - quite cheaply - is excellent - doesn't matter if it gets wet or dirty - just wash it when you get home - hang on the line to dry. - have also thought of campers with pull out kitchens that the air goes in under the trailer (bed) - we alsways make sure we close our end in the evenings for this purpose - keep as much cold air out as possible.
happy camping - jules
FollowupID: 425012
Reply By: Brew69(SA) - Friday, Apr 28, 2006 at 17:07
We take hot water bottles camping, and with the purchase of the coleman hot water on demand it makes it all the easier. We have used them in tents for ages and the kids don't complain either.
AnswerID: 169522
Reply By: Brian B (QLD) - Friday, Apr 28, 2006 at 17:11
We have a really good quality doona on the bed that is great even in the coldest conditions. On top of that we rug up well and wear beanies on the old scone and ugg boots on the feet. Mightn't make the worlds best fashion statement but they are great.
This seems to work well for us.
AnswerID: 169524
Follow Up By: Robin-Outback - Friday, Apr 28, 2006 at 19:11
Proper duck down doonas are awesome. Not cheap but incredible for warmth. Wear explorer socks to bed and woolen beenie.
FollowupID: 424874
Reply By: agsmky - Friday, Apr 28, 2006 at 17:17
Everyone knows you 'spose to head north for the winter to avoid this dilema!!
andrew
AnswerID: 169528
Reply By: AdlelaideGeorge - Friday, Apr 28, 2006 at 17:25
another really good addition to the ideas offered is top quality wool long johns and top - they REALLY help.
AnswerID: 169531
Reply By: Muddy doe (SA) - Friday, Apr 28, 2006 at 17:35
We went to Ray's out door emporium and purchased 2 Roman "Swag Bags" they are a large sleeping bag.
We then zipped the 2 together to form a sleeping bag that more than covers a queen size bed. Not restrictive at all and it is WARM! Does take a bit of space though unless you really scrunch it down. We lay it over the top of all the gear in the car so it does not really matter but if you have a whole family you might be pressed for room and will have to roll it really tight.
As it is so large it does not feel like you are in a bag, more like a big doona top and bottom, but it still stops heat escaping from the sides.
Were $99 each but we went during a 24.5% off sale so paid a reasonable price.
Muddy and Judy
AnswerID: 169535
Follow Up By: Trevor R (QLD) - Friday, Apr 28, 2006 at 20:27
Still being new to the engagement scene, I would have thought you guys would have no need for such bed warming necessities. Other ways to keep warm come to mind for newlyweds hahaha.
Hope you are both going well.
Trevor.
FollowupID: 424887
Follow Up By: Muddy doe (SA) - Friday, Apr 28, 2006 at 20:35
Hah!
Thanks Trevor, all going fantastic. Can't say much more than that as this is a public forum!
We will have our camper unit set up on a temporary trailer by the end of the weekend so we look forward to getting away in it over the next few weeks and months.
M&J
FollowupID: 424893
Follow Up By: Muddies Doe(Trippn) - Friday, Apr 28, 2006 at 20:44
Hi Trevor
Hahahahaha.......a comment was pssed to Muddy but he reframed from using it..... :)
It's colder down here then in sunny Qld...something I well miss.......but I love my man so I wll endure........ :)
Newlyweds?..........hehehehe........a ways to go for that one, but one we can't wait to become.
Cya
FollowupID: 424896
Follow Up By: Jimbo - Friday, Apr 28, 2006 at 20:49
Be warned Steve,
There has been a scientific study completed that has proved that the primary decrease in female libido is attributed to...............................
consumptiom of wedding cake LOL.
Good luck to you both.
Jim.
FollowupID: 424900
Follow Up By: Trevor R (QLD) - Friday, Apr 28, 2006 at 20:49
Jude,
Newlyengaged's just didn't sound right so I distorted the truth a little to make my point. Whatever, most would understand you would still be finding it hard to come up for air hahahahahahaha.
Cheers.
FollowupID: 424902
Follow Up By: Muddies Doe(Trippn) - Friday, Apr 28, 2006 at 20:56
Hi Jimbo
LOL..........funny one....... :)
Hi Trevor
Oh, I have a great reply for that one.....sorry I can't give you a reply, seeing it's an open forum........lol
Cya
FollowupID: 424906
Reply By: clarkie63 - Friday, Apr 28, 2006 at 17:54
Fill up your camp oven with coals from the fire and place in tent on a couple bricks or piece of fibro,. Warm as toast. If you are worried about fire buy a battery operated smoke detector- cheap cost for peace of mind.
AnswerID: 169537
Follow Up By: Muddies Doe(Trippn) - Friday, Apr 28, 2006 at 18:02
Hi Clarkie
What a great idea, so simple yet effective!
We can't wait to try it out VERY soon.
Much thanks.
Cya
:) & Muddy
FollowupID: 424857
Follow Up By: Member - Blue (VIC) - Friday, Apr 28, 2006 at 21:46
I have used this before and it works... Thinking of the fire risk, I packed a square(500x500mm) cement sheet, stuck that on the floor, 3 bricks on top and stuck the oven on that.
Now with little kids, that one has gone out the window...
FollowupID: 424924
Reply By: Member - Paul P (Bris) - Friday, Apr 28, 2006 at 18:11
G'day
Before using any type of combustion heater (gas,hot coals etc) in a confined space may I suggest a Google on the words Carbon Dioxide and Carbon Monoxide.
The life saved could be yours...
Paul
AnswerID: 169541
Follow Up By: Robin-Outback - Friday, Apr 28, 2006 at 19:08
The Coleman catalytic heaters are approved for use in caravans tents and everywhere else with ventilation. Look at all the millions of Australians with gas heaters gas cooking gas hot water systems gas rings and stoves in caravans. Now explain the difference compared to a catalytic heater which uses 20% of the gas of a gas ring to boil water. Caravans and campervans have to be vented floor and ceiling to Australian standards and with the ventilation you could run 5 catalytic heaters in caravans or campervans. Seen you are so keen on supplying alarmist information via Google go and look at catalytic heaters and the benefits they have.
Everything is dangerous so stop driving, stop using electricity, stop breathing, stop been alarmist.
FollowupID: 424870
Follow Up By: Kiwi Kia - Friday, Apr 28, 2006 at 20:13
Dead right Paul, I have seen many coronors reports on carbon monoxide poisoning in both tents and caravans.
FollowupID: 424885
Reply By: Alloy c/t - Friday, Apr 28, 2006 at 18:20
OK ,you can all start laughing now , way way back in time when I was a member of the green machine [none of that cant see me camo uniform back then] to keep warm in the cold and wet scrub , pantyhose !!! yes pantyhose with a stategic hole cut in the area required ,,,better than long johns / less weight /quick to dry / cheap / easily replaced / and oh ever so comfy !!!!!
AnswerID: 169543
Follow Up By: Tony J - Friday, Apr 28, 2006 at 19:05
Yep, I agree, but I'm not game enough to tell my wife this trick! I learnt it on bikes along with newspaper down the jacket, when I was in the green machine. Hadn't met my wife back then. I don't want her to think I'm some sort of weirdo cross-dresser!!!!
FollowupID: 424866
Follow Up By: Member - Paul P (Bris) - Friday, Apr 28, 2006 at 19:07
Yep work fine BUT I know why legs are shaved when stockings are worn :-) OUCH!!!
Paul
FollowupID: 424869
Follow Up By: Brew69(SA) - Friday, Apr 28, 2006 at 19:12
Guys guys guys...............let me guess..........you drink Chardonnay too? There are women folk who read these pages too lol.
FollowupID: 424875
Follow Up By: Member - Oldplodder (QLD) - Friday, Apr 28, 2006 at 19:53
Hey Brew, hope you are not knocking chardonnay?
FollowupID: 424882
Follow Up By: Alloy c/t - Friday, Apr 28, 2006 at 19:56
Brew69 , nothing wrong with the odd glass of chardy ,goes down really well with some smoked salmon and fresh oysters ,and to finnish off a dram or 3 of Johnny Walker Gold Label. lol.
FollowupID: 424883
Follow Up By: Muddies Doe(Trippn) - Friday, Apr 28, 2006 at 20:49
Boys Boys Boys
Glad to see you are getting in touch with your feminine side.
Cya
FollowupID: 424901
Follow Up By: Mr Fawlty - Saturday, Apr 29, 2006 at 18:38
As a retrenched jungle warrior I can recount many stories of bronzed Aussies wearing panty hose, not for warmth, it the tropics you get a very sticky crutch, but for leaches. The only non odourous way to keep the buggers off. & they (leaches) can do serious damage if they decide to have a go at the inside of your eurethra while you are trying to sleep...
FollowupID: 425034
Reply By: Member - DickyBeach - Friday, Apr 28, 2006 at 20:09
We spent 3 months (June-Sept) in WA - CSR and all the desert NPs - in a KK and cold wasn't much of a problem. A good, and I mean good, doona (feathers/down, not synthetic) and a soft warm wife works wonders.
Most of the time I didn't need a shirt top or similar, and my head has as much hair as a bowling ball and I don't own a beanie so heat loss from the head never was an issue.
SWMBO doesn't drink, so that (sort of) limits my alcohol intake, and in any event when the Scotch wears off you're colder than before (by the way, it took me years to realise it, but I now know that it's sleep that causes all the turmoil in the morning - I'd go to bed after a night on the p**s feeling great but wake up crook, so it just had to be the sleep that caused the problem - but I don't recall that being a problem.
Wifey, on the other hand, seemed to wear everything she had to bed (but maybe that was her way of ensuring an uninterrupted night's sleep :) ).
DB
AnswerID: 169557
Follow Up By: Trevor R (QLD) - Friday, Apr 28, 2006 at 20:33
Yours and my SWMBO must have went to the same school. Every time I hit the turps she dresses for bed :-)))))
FollowupID: 424891
Reply By: Steve - Friday, Apr 28, 2006 at 20:16
We got a kero heater to take the chill out of the van/tent and have hot water bottles in bed. Keep yourself warm before you hit the sack and wear good socks and a beanie.
AnswerID: 169560
Reply By: Member - Mike DID - Friday, Apr 28, 2006 at 20:51
If you have a campfire, take one of the rocks that was beside it and wrap it in newspaper and a towel and take it to bed - lasts longer than a hotwater bottle.
Mike
AnswerID: 169573
Follow Up By: Brew69(SA) - Friday, Apr 28, 2006 at 20:58
Is that how u get your rocks off?
FollowupID: 424907
Follow Up By: Jimbo - Friday, Apr 28, 2006 at 21:39
ROFLMAO Stu.
FollowupID: 424921
Reply By: arthurking83 - Friday, Apr 28, 2006 at 22:01
I'd be wary of any combustion heating in a confined place too! (approved or not!!)
Of course it's only by trial and error that they finally DIS-approve of them, isn't it! :o
How about a good quality 'butterfly-zip' sleeping bag??
You fully unzip it and use it as a double doona style covering!
(takes up much less space than a doona)
I used mine this way in a Central Deserts trip over winter some years back.
-5°C most nights and I was raising a sweat!......My nose got really cold though!
AnswerID: 169588
Follow Up By: Alloy c/t - Friday, Apr 28, 2006 at 22:06
My nose got really cold though !! Woof Woof Woof , Lol . good thing there were no dingos about.
FollowupID: 424928
Reply By: Des Lexic - Friday, Apr 28, 2006 at 22:40
Make sure your warm before you go to bed. Try a Cockle Warmer. Works wonders especially with the girls.
AnswerID: 169600
Follow Up By: Muddies Doe(Trippn) - Friday, Apr 28, 2006 at 23:40
Hi Des
I had my first cockle warmer on the Goog's recently.
Muddy got a bit overzealous with the first lot of coals and I got quite warm, quite quickly.
Can't wait to have another one though. :))))
Cya
FollowupID: 424954
Follow Up By: Bonz (Vic) - Saturday, Apr 29, 2006 at 19:08
what if your cockle is warm and its your hands that are cold??
FollowupID: 425042
Follow Up By: Muddies Doe(Trippn) - Saturday, Apr 29, 2006 at 19:16
Hi Bonz
Well I wouldn't recomend coals for cold hands........although.
I suggest maybe putting them in mittens, gloves, pockets or maybe someone else's pockets??? :)))))
Cya
FollowupID: 425044
Reply By: rainer - Saturday, Apr 29, 2006 at 11:44
Thank you very much for all your suggestions.
Rainer
AnswerID: 169650
Reply By: gen3rules - Saturday, Apr 29, 2006 at 18:14
small invertor and an electric blanket works wonders
AnswerID: 169695
Follow Up By: Member - Mike DID - Saturday, Apr 29, 2006 at 19:12
You can now buy 12 volt Car Blankets
Mike
FollowupID: 425043
Reply By: Barnesy - Saturday, Apr 29, 2006 at 19:03
good beanie on the head, feather down quilt (doona), opened sleeping bag over the top and wear jumper, socks to bed
AnswerID: 169702
