Question about Oil Filter for 1HZ Motor
Submitted: Wednesday, Apr 26, 2006 at 17:38
res.q.guy
I was talking to a mate yeaterday, who said he only uses genuine Toyota oil filters for his 1HZ motor as they have a valve in them, that keeps the oil in the filter, and doesn't drain out when the motor is stopped, hence quicker oil pressure when you start the motor, and other brands of oil filter don't.
Can anyone confirn or deny this ? as I haven't heard of this about different brands of filters before.
Thanks in advance.
Neil
Reply By: Footloose - Wednesday, Apr 26, 2006 at 17:55
Neil, this is quite correct.
169139
Follow Up By: Footloose - Wednesday, Apr 26, 2006 at 18:01
The 80's cool tech pages have a pix of the insides of a genuine and non genuine filter. Very different indeed.
424473
Reply By: SteveL - Wednesday, Apr 26, 2006 at 17:57
What your mate says is more than likely true.It is the same situation with the non-geniune Nissan filters.Most (if not all) non-geniune filters do not have an anti-drain back valve that works, meaning it takes 7-8 seconds to get full oil pressure (instead of 1 or 2 seconds) when left overnight or even for a few hours.Cold starts is where most engine wear takes place, of course.-Steve
169140
Follow Up By: kesh - Wednesday, Apr 26, 2006 at 19:00
Neil. Always used Toyota 1hz. filters until at one change I had to use a Repco one. This obviously didnt have the anti drainback component, it always took several seconds to get oil pressure at each start from cold.
Was only about 1500km. when off it came and the genuine one on.
However I have also used (its on now) a Fleetguard filter which seems identical to Toyota in oil pressure build up response. Would be happy with that brand, but so little diff. in price the oem goes on in preference when available.
Toyota is somewhat lacking in many outback towns, rely on o/n delivery which is not always convenient.
kesh
424493
Reply By: Tony J - Wednesday, Apr 26, 2006 at 19:55
Well, I guess I'll take a different view. I got my 1hz at 60k. I took it back because the oil pressure light stayed on for a couple of seconds when first started each morning. It was a genuine Toyota filter. The dealer changed the filter but still did the same thing. They then put a you-beaut gauge on it and said that it was within spec. The Ryco box says they have the anti drain back valve. Still have the light on for a couple of seconds. Valvaline filter leaves the light on for several seconds and one other (expensive brand but I can't remember it - related to heavy transport) was the worst. Took that off the day after I serviced the car. Now over 230k and still going strong.
169164
Follow Up By: Member - Stephen M (NSW) - Wednesday, Apr 26, 2006 at 22:13
Hi there Tony, my hilux does the same thing couple of seconds for oil light to go out on first start up in the mornings even with genuine oil filter thats all that has ever been used. Its coming up for 300k now and never had any problems with oil or blowing up the old 2.8 presumably a common problem with the 2.8 going bang but I think alot to do with them going bang is a lack of oil changes.Mind you I do myn every 3k + filter bit overboard I know but hey still going and cheaper to find $40 than 6k for a rebuild. Regards Steve M
424556
Reply By: 120scruiser (NSW) - Wednesday, Apr 26, 2006 at 20:26
Interesting subject.
The "anti drain back valve" is in most filters.
After this was discussed a few weeks back I cut several filters open at my workshop.
We remove them from cars and tip them upside down to drain before disposal.
I cut open, toyota, mazda, holden, subaru, ryco, cooper, AC Delco and the one that held the most oil was the elcheapo Fram. All had drain back valves of difference materials. The Toyota one was very soft as opposed to the Fram one.
I examined my oil light on my new Prado with a Toyota Filter at start up and have recently changed to a Fleetguard. Both much-of-a-muchness.
I wrote all the findings down somewhere and if I find where I can post but don't hold your breath.
No point to this just interesting stuff how the cheapo retained the most.
The next from memory was the Cooper. Now also interesting is Cooper is part of Ryco and both are owned by Wesfil. Now Wesfil is a cheaper brand and all filters were different.
Just my two bobs worth
120scruiser
169175
Reply By: bigcol - Wednesday, Apr 26, 2006 at 20:59
Ever heard a Ford service manager saying that their equivelent of a Z9 oil filter has a valve in it and a Ryco doesn't. Even stranger that they're the same thing but don't share the same case
169187
Reply By: Member - Phil G (SA) - Wednesday, Apr 26, 2006 at 21:07
The other difference is that the filter is a dual stage filter. Its got two sets of filters - one fine, one not so fine. I'll always use genuine filters for fuel and air as
well. Not worth the risk.
I buy my Toyota genuine filters in bulk off Ebay - theres a seller there that sells 10 filters for $275 delivered. Thyese are the genuine Japanese made Toyota filters for 1Hz, 1HDT, 1KZ-TE etc. Usually sell a few on to mates.
169192
Reply By: The Rambler( W.A.) - Wednesday, Apr 26, 2006 at 22:12
All I can say that the company I worked for uses many Toyota Diesel vehicles--mainly 78&79 series and have used Ryco filters for years with no problems.WE had one sold at over 600000kms without any major work.I only use Ryco on my troopy(and I have had a few) with no problems.The real answer is REGULAR oil changes with filter.
169207
Follow Up By: Member - Stephen M (NSW) - Wednesday, Apr 26, 2006 at 22:17
Agree with you there Rambler in regards to regular oil changes or though I still use genuine filters cause I can get them for $11 each as I use to work for them for a while and still know alot of people there but yeah your spot on in regards to changing the filter as
well as the oil.Regards Steve M
424557
Reply By: Billowaggi - Wednesday, Apr 26, 2006 at 22:20
This all makes me feel good that the 3 vehicles in my family all have the oil filter hanging down so no chance of drain back, instant oil pressure on start up.
Regards Ken.
RA Rodeo 3.0td
TF Rodeo 2.8td
EF Falcon 4.0
169208
Reply By: Geoff M (Newcastle, NSW) - Wednesday, Apr 26, 2006 at 23:08
Hello Neil,
It's surprisingly easy to tell if the filter you're about to fit has a non return valve or not.
Look at the mating surface of the filter, one big threaded hole and a ring of smaller holes around it. The oil enters the filter via the ring of smaller holes and exits via
the big hole. Why? The filter is a cylinder and cylinders always have more external area than internal area, that equals more filter area.
Now, how to tell if the filter has a non return valve. You'll always be able to see right inside the filter through the larger hole with or without the non return valve. If the ring of smaller holes are covered by something resembling rubber then it has a non return valve. If you can see right into the filter through the small holes then it doesn't have a non return valve.
Geoff.
| Geoff,
Landcruiser HDJ78,
169225
Reply By: Kiwi Kia - Thursday, Apr 27, 2006 at 07:28
A few extra seconds before oil pressure comes up is no big deal. Yeah, yeah, more damage is done during cold start etc. etc. Dry sump aircraft engines require that oil pressure comes up within 30 seconds. Oil is sticky when its cold and leaves a good film on everything don't worry about a few seconds 'wear' on start up.
I recently (Christmas party) watched some
young mechanics (big truck garage) try and kill a couple of cars they had got from the wreckers. First they played crash and bash stock cars then when they would not move anymore they put a brick on the accelerator pedal and rev the *** out the engines till they explode. One car had already lost all it's oil during the crash phase of the exercise. Half drunk
young guys thought it was a fantastic party till a neighbour rang the fire brigade when they saw heaps of smoke comming from the yard. Boss fireman was not to pleased but finally saw that it was all fun and no danger to anyone. Anyway, even with no oil the engines ran on full throttle for over five minutes (probably close to ten) before giving up. These were clapped out 150,000 - 200,000 k's engines.
169250
