Wednesday, Apr 26, 2006 at 10:56
Hi Di
Consider doing neither, as I did.
Its very easy to increase the weight of car by 100kg (3%) and
increase its wind resistance significantly adding up to around
2-3% increase in fuel use - more if you do
driving lights as
Roo bars do work - but are somewhat overated , the car has standard
plastic bar, but underneath , spaced 2-3cm away is a complex steel sub bar
(16kg) which acts very effectivily in conjunction with the plastic outer
shell.
I go regularly into a heavy roo area, so much so that one hit me one very
windy stormy night while I was parked !
Unfortunately I hit a medium roo with my GU straight on at around 70kmh.
It was killed instantly, but the car suffered only a 5cm split in the outer
plastic bar as it did the job it was designed to do.
I required no repairs whereas an alloy bar certainly would have.
A bigger harder hit would have done more damage and there clearly is a point
that an ARB etc bar would have done better but I feel the trade offs are worth it
particularly after driving a few with bars that make the already front heavy car
into a real understeerer.
Robin Miller
P.S. fitted a winch at net weight gain of 30kg to my standard bar.
169046
Follow Up By: Member - Beatit (QLD) - Friday, Apr 28, 2006 at 12:00
G'day Robin,
Now I'm not going to disagree with you on this but just as a side issue I had to replace the rubber outer on the rear following an altercation with a rather billigerent tree. It was only creased but just looked wrong to leave it the way it was so started looking for a replacement. The shock was that the item cost $360 give or take from Mr Nissan and that did not include the metal brackets underneath. Fortunately was able to source one through your other web site interest but it made me aware of how expensive these relatively cheap looking arts can be. I suppose though that front bars are dime a dozen from bull bar fitters and possibly could be cheaper.
Kind regards
424782
Follow Up By: Robin - Friday, Apr 28, 2006 at 13:44
Hi Beauit
Yes I agree the cost of some things seems out of all porportion ,while I ultimately choose the Nissan standard bar because it meet my critirea best , I hung around
the various outlets and picked up a complete spare at zero cost , cause one day I just might meet a bigger roo!
Robin Miller
424802
