Uprating a Nissan weight
Submitted: Monday, Apr 24, 2006 at 21:38
Bilbo
As some of you would know, I recently upgraded a 2.8 turbo diesel Nissan Patrol with a 6.5 litre V8 Chev and uprated springs, shockies, gearboxes and diffs and a heap of other stuff.
The vehicle is now, literally, the same spec as any other Nissan Patrol. I now want to increase the towing weight from the normal 2850 kgs for the 2.8 turbo Patrol to the weight applicable to a say a 4.2 Patrol, which is 3500 kg.
This would entail dealing with the vehicle Inspectors in the Dept of Planning and
Infrastructure at
Welshpool here in W.A.
Thanks,
Bilbo
Has anyone had any experience of what's involved?
Reply By: froomey - Monday, Apr 24, 2006 at 21:55
hi bilbo
the company that done your conversion should have done that for you on completion of the conversion, did they licence it for you as a 6.5 or you do it your self
froomey
w.a.
168793
Reply By: ZUKSCOOTERX90(QLD-MEMBER) - Monday, Apr 24, 2006 at 21:58
Hi, Bilbo i am not sure on this answer but i would think you would have to go to the transport office let them know what you want to do, then they would tell you yes or no.If yes i would say you would have to upgrade you're tow bar goose neck & ball weight & possibly have it certified ( no not you) by a certified engineer. Those are just my thoughts . Cheers & happy motoring, Bob.
168794
Reply By: Geoff M (Newcastle, NSW) - Monday, Apr 24, 2006 at 22:11
Hey Bilbo,
Just after second breakfast on Wednesday give Brunswick a buzz. I'm pretty sure your not the first of their customers to face this problem.
Geoff.
| Geoff,
Landcruiser HDJ78,
168797
Reply By: Member - Bruce H (WA) - Monday, Apr 24, 2006 at 22:54
I new member and drive one of these 2.8 GU demons. The drawbar tongue from my beast says:-
NISSAN.
Max. Capacity (Braked) - 3500Kg.
Max. Capacity (Unbraked) - 750Kg.
Max. Static Ball Load - 200Kg.
Towbar Part No. G1962-VB010A
If the 2.8 does have a lesser capacity then who would be responsible if it was exceeded. Having only owned this horse for 2 years I can but assume that the bar was fitted by the agents from new.
Not sure how keen the pony would be with 3.5 tonnes up its blunt end but with a good downhill start I'm sure it could keep things moving.
Inerested to read any comments.
Thanks, Bruce H.
168804
Follow Up By: Sparkiepete - Tuesday, Apr 25, 2006 at 05:56
Although the drawbar tongue reads what it says I think you need to check the specs of the actual vehicle to find what it is rated at.
Sparkiepete
424184
Follow Up By: Member - Bruce H (WA) - Tuesday, Apr 25, 2006 at 08:46
Thanks Sparky/Pete,
Nothing in handbook and only info ID plate is:
GVM 2960.
Don't know relationship between GVM and towing capacity, or if there is one.
Did find this info from Haymen Reese, but not clear guidelines.
http://www.haymanreese.com.au/consumer/advice/index.htm#2
And this but no 2.8 GU
Site Link
Interesting that GU Auto's are substantially less towing mass than manual trans.
Guess it's too late to be finding out when Mr Dibble is weighing things and says "Yer over-----". They don't often have a great sense of humour.
424195
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 09:19
Bruce,
GVM is the total permissible weight for that vehicle without a trailer attached. This is an "all up" figure and includes such thngs as fuel, oil in the sump, any load in the vehicle, cartons of beer, etc
It's the maximum that you can go to WITHOUT a trailer.
GCM is Gross Chassis Mass - which should be somewhere around 5 tonnes for a Patrol. This figure is again an "all up" figure, including a trailer and whatever the trailer has in it or on it.
It is generally regarded that auto gearboxes are not as strong as manual boxes. (Although there are some auto boxes that are real beauties). Hence, a vehicle with an auto box is generally downrated when compared to a manual gearbox. If they are overloaded they slip and eventually "burst".
Bilbo
424199
Reply By: Bilbo - Monday, Apr 24, 2006 at 23:21
Answers for all,
A 2.8 Patrol may
well have a 3500kg towbar fitted, but the vehicle as a whole is not rated for 3500 kgs. All it means is that it has a 3500 kg rated towbar. Check the books or the compliance plate. The gearbox is the weak point along with the 2.8 engine. Everything else is the same as the bigger engined Nissans. That's the problem here. My truck is now identical to a 4.2 or a 3 litre - except for the 6.5 litre engine, but my plate says "2850 kgs only".
I've asked Greg Jones at Brunswicks if he coulkd get the certifying engineer that plated the engine to also re-plate the towing capacity at the same time. He told me that he's been asked for this before but neither he nor the engineer is allowed to rerate the towing capacity. That job has to be done by DPI inspectors and them only.
Hence my question.
Bilbo
168809
Follow Up By: Richard Kovac - Tuesday, Apr 25, 2006 at 00:44
Bilbo
I think it may have something to do with the size of the brakes, axles, etc.
and as you say gearbox and diff. Power only has to do with the time it takes to tow not the strength of the components
Phone DPI inspectors and ask them they should be able to tell you
Richard
424179
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 09:30
Richard,
I've done SOME checking with Nissan and I've had experience with Nissan Patrols in years gone by. It seems that the brakes, axles, bearings, chassis members, brake boosters, steering components etc on a 2.8 are exactly the same as any other Patrol, 4.2 or 3 .0. The limiting factor appears to be the strength of the gearbox and the size of the engine.
I'm merely asking "Has anyone been down this road before with the people at DPI in W.A.?
Another way of putting it would be "Do I have get every part number and part description from Nissan to prove my case or can I get an engineer to just certify it and then present that to the DPI?"
My motto is "To be forewarned is to be forearmed"
Bilbo
424204
Follow Up By: Bonz (Vic) - Tuesday, Apr 25, 2006 at 09:51
Call an engineer and ask them what you need to do, or go back to your ngine mob and get them to do the runningaround
424210
Reply By: crfan - Monday, Apr 24, 2006 at 23:41
Didn't you askbefore you started ?I was going to build another trailer for
camping and was was going to build big ,and how I want it , but talking a Mate in the licening area I dont think I can with out making to heavy to tow.
168812
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 08:56
Crfan
My caravan is
well under the current weight limit of the vehicle which is 2850kgs. I'm not in a pickle about this. It isn't a problem. BUT why not have the increased weight limit if it can be obtained?
The question is "How much messing about is this excercise gonna take?" The next question is "Is it worth the effort?"
Bilbo
424197
Reply By: Member - Vincent A M (NSW) - Tuesday, Apr 25, 2006 at 08:57
Most states just require an Authorised engineers report
the Gov department in your state should have a list of approved engineers
My 4.2 has been up rated to 4500kg due to 6 wheeler conversion
168846
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 09:20
Thanks Vince. Proves it can be done at least.
Bilbo
424200
Reply By: Bilbo - Tuesday, Apr 25, 2006 at 09:09
Guys,
In light of my experience many years ago as a truck mechanic and having been a qualified Vehicle Inspector years ago in the U.K., perhaps I should rephrase the question:-
"How much of PIA are these government inspectors at
Welshpool in W.A. and has anyone had similar dealings with them?"
Bilbo
168849
Follow Up By: Old Scalyback & denny - Tuesday, Apr 25, 2006 at 09:33
goodday bilbo
can you attack the govt site concerning your problems and see if they have an answer
steve
do you find with the 6.5 you save on fuel or are you busy dragging off at the lights still
424205
Follow Up By: Bonz (Vic) - Tuesday, Apr 25, 2006 at 10:48
ahhhhhhhhh My experience would be: There are PITA's and good blokes,
test them out on the phone and see if they are rule staters or solution providers and make your decision.
424221
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 11:09
Thanks Bonz.
Scalyback,
I'm trying (desperately) not to drag race at traffic lights - but it does happen.
I wonder what these things redline at?
Bilbo (still "running in")
424227
Follow Up By: Bilbo - Tuesday, Apr 25, 2006 at 11:16
Whoops,,,,,,,,,
Scalyback,
Kms per litre = 6.01
Litres per 100 kms = 16.63
MPG = 16.99
These figures were over a distance of 380 kms consisting of about 80 kms towing a 2 tonne van and city driving. I used to get the same figures as those above from my former 100 Series TD 'Cruiser when towing a 2.8 tonne van on long, country trips. So I reckon the consumption is slightly worse than the TD Landcruiser. But it's still a "tight" motor and it may improve. It's still better than a big petrol engine though.
Bilbo
424230
Reply By: J.T. - Tuesday, Apr 25, 2006 at 16:36
Bilbo,
Just curious,but what do Brunswick diesels do with all the original engines removed from vehicles to fit their v8s.
168916
Follow Up By: Bilbo - Wednesday, Apr 26, 2006 at 09:30
JT,
When the conversion is done, Brunswicks will give a "trade in" on the old motor if it's in serviceable condition. I didn't get anything as my engine was stuffed. But they must sell 'em somewhere but I don't actaully know where or how.
My truck goes in for its first service at Brunswicks tommorow - I'll ask.
Bilbo
424380
Reply By: Trevor R (QLD) - Tuesday, Apr 25, 2006 at 18:41
Bilbo,
Try Member Messaging "Member Lucy" in Vic as he has done an increase in GVM on his Troopie. If anyone would know, I think it may be him.
Good Luck
Trevor.
168942
Follow Up By: Bilbo - Wednesday, Apr 26, 2006 at 09:33
Thanks Trev,
Now how do PM him? Don't worry, I'll work it out.
Bilbo
424383
Follow Up By: Trevor R (QLD) - Wednesday, Apr 26, 2006 at 17:34
Bilbo,
If you like I can send Member Lucy an email and get him to email you. This would obviously mean I need to pass your email address onto a third party so if you want me to do this, drop me an answer here or by email. Otherwise I won't hand out your email address to anyone.
Best Regards Trevor.
424461
Follow Up By: Bilbo - Wednesday, Apr 26, 2006 at 23:23
Thanks Trev, but I am a member on this site, so I can PM from here.
Bilbo
424568
Reply By: V8Diesel - Wednesday, Apr 26, 2006 at 09:38
Sold my 21 year old 75 series with a Brunswick 6.5 last week. Already back to thinking about putting one in my 105 Landcruiser.
Now that you've had a few weeks to settle in to your new rig, what's your opinion on the current 6.5 V8 conversions? My one was done 8 years ago and I from what I've seen, they have changed dramatically since then. Anything you'd do differently second time around? Your opinion on anything whatsoever to do with the conversion?
I'm still undecided as to which way to go. A simple, 'true' non-electronic diesel appeals to me greatly and I would end up with pretty much my ultimate 4x4 vehicle, but the cost is hard to justify and in all honesty, my petrol motor is a gem with oddles of torque from idle (and below). I do love a thumping big V8 though and the range of a diesel with LR tanks is a bonus for those very remote areas.
169030
Follow Up By: V8Diesel - Wednesday, Apr 26, 2006 at 09:48
Forgot to add, my 6.5 took a lot of km's to 'free up'. I think they'll be a long lasting donk.
Here's something to
test. Try driving it around
the block a few times without any air filter or piping on. Unrestricted just straight into the inlet manifold. I found my 6.5 was being strangled by the standard filter and
snorkel setup, and I instantly gained about 25% more 'driveability'. Obviously this is not a premanent option so I bought a quality K&N pod filter for around town / bitumen use and the improvement was spectacular. I think they may use a Donaldson now but it's worth the 2 mins to
check it out.
424389
Follow Up By: Bilbo - Wednesday, Apr 26, 2006 at 23:16
V8,
There's not a lot I would do differently. MAYBE I would go for a higher 3.7 diff ratio as I reckon this would pull that no probs, even towing a 2 tonne van. I'd also recommend that anyone that has it done gives it a good load in REVERSE test to check that the drivers side exhaust isn't hitting the bell housing or body work on reverse torque. Mine is and it's a shocking noise. They're fixing that tomorrow. It seems to be a common complaint. Also give 3rd gear a good workout for jumping out of gear on the overrun. This one does it and again it is a common fault as the body "pushes" against the gear lever if they haven't cut enough out of the surrounding bodywork and rubber seal. They're fixng that as well - otherwise I'l be having a new gearbox! The electric fuel pump that they fit is very noisy and I'd be asking questions about that - "can it be toned down a bit please?" I'll be fxing that myself.
I'd also think about some serious noise supression matting - the proper stuff. It's not ear bending noisy but I've been spoiled by my former TD Landcruiser and, by comparison, that was quiet. But this Chev/Trol is still quieter than my old Ford Maverick ute. The exhaust is the bulk of it, followed by the diesel rattle.
Nothing else really.
Bilbo
424566
Follow Up By: Bilbo - Wednesday, Apr 26, 2006 at 23:20
PS - Thanks for the air filter tip. Not sure how a K&N would go in the dust in the Goldfields though. Should be OK around town.
Bilbo
424567
Follow Up By: V8Diesel - Thursday, Apr 27, 2006 at 07:57
Thanks for that Bilbo, much appreciated.
Re: the K&N, I only used mine when driving on the bitumen and then would swap it back over to the snorkle for the serious stuff. Just loosen the hose clamp and slide the rubber pipe off that ali right angle dooickie that sits on top of the inlet manifold and swing it out of the way. K&N filter out of its dust proof bag and clamp onto the 3" pipe along with an old pillow case to stuff up the pipe so dust can't get into the 'clean' side of the pipe. A one minute operation.
Was definately worth the effort on mine, but chances are they've come up with a less restrictive system since 1998.
424582
