tyre sizes re. TRITON
Submitted: Thursday, Apr 13, 2006 at 20:34
ThreadID: 32870 Views:3873 Replies:4 FollowUps:4
Hi there, my 04 triton ute has 205/80r16 tyres on standard steel rims. just wondering whats the largest tyre i am able to fit to the standard rim?
Reply By: bob007 - Thursday, Apr 13, 2006 at 21:02
hi kath
my mate has 265/75 bf muds on a two week old triton with no suspention lift hope this helps
cheers bob
AnswerID: 166935
Reply By: Member - Blue (VIC) - Thursday, Apr 13, 2006 at 22:13
Katherine, I have an '03 GLX... When I got new tyres, I was told 225/75-16 was the largest I could safely put on the 6" standard rim. I have 31-10.5-15 muddies on a set of 7" sunraysia's, they fit well and don't scrub anywhere. the 15x7 sunraysia's were about $50 each.
AnswerID: 166948
Follow Up By: Katherine - Friday, Apr 14, 2006 at 08:52
Thanks for advice, after reading your response and doing a bit of net surfing 225/75R16 AT is probably my best opition (without changing rims and keeping my insurance company happy).
Katherine
FollowupID: 421990
Follow Up By: Katherine - Saturday, Apr 22, 2006 at 18:13
Hi there
Its been a few weeks since i asked the question re triton tyre sizes.
Been thinking about what you wrote and have a few more questions.
31/10.5R15 (774) vs 225/75R16 (744).. 30mm hieght difference in O.D
When running 31's is the speedo affected much??
We also own a GLX which doesnt have flares, do the 31's stick out much past the guards??
thanks
Katherine
FollowupID: 423815
Follow Up By: Member - Blue (VIC) - Saturday, Apr 22, 2006 at 23:53
Hi there Katherine,
Best I can figure is about 5k's out. Driving next to my wife(she was in our Falcon) She sat dead on 100kph and I was almost spot on 95kph on my speedo. Using 5kph as a rule of thumb, I have managed to avoid any speeding fines, although I only have the 31's on 4 or 5 times a year and rarely for more than a week or so.
I think someone posted a %-out calculator for increased/decreased tyre diameter a while back, might be worth another post, in fact I'll get on it right away...
Blue
FollowupID: 423867
Reply By: boogyman - Friday, Apr 14, 2006 at 04:41
assuming its only a 6 inch rim?? i would go to a 7.50 r 16 you can get some good off road tyres a bit cheaper wit this option
AnswerID: 166967
Follow Up By: boogyman - Friday, Apr 14, 2006 at 04:43
forgot to mention that the 7.50s are equivalant to a 32 inch tyre
FollowupID: 421968
Reply By: Member - Oldplodder (QLD) - Friday, Apr 14, 2006 at 19:23
Quick calculation. 205/80 16
16" = 406mm
205 * 0.8 = 164mm - *2 = 328mm
Total OD = 734 mm
In theory you can only legally go up 15mm in diameter = 750mm OD
= approx 29.5" OD
(There are some on this forum who will debate this 15mm figure)
225/75 16 would work at 743 mm OD
I run 235/85 16 on 16"x6" rims - 805mm or 32" OD, which is about the biggest tyre you can mount on that rim.
7.5 x 16 ( = 190/16) is a little narrower, easy to get, and 32" OD.
Don't you love this mixing of metric and imperial in tyre sizes !!!
AnswerID: 167047
