Tuesday, Apr 04, 2006 at 00:15
Hi Sharyn M,
Dependiong on what (how old??) your laptop is!
If you are running Win98 try to avoid a USB mouse. Get a serial version!
(while people are having much success with Win98 and USB (devices) they are not the best match!
(Better still...now would be a good excuse to upgrade to WinXP!)
If you have a modern lappy, (and hence WinXP) then a GPS 'mouse' wouldbe your best option!
I would use a CF GPS, for the reason already mentioned...reception!
the better option would be a Bluetooth GPS (only if you use WinXP!)
wireless, and generally better... something like the "
Globalsat BT338" is a very good chipset GPS, and possibly one of the best!??
....will keep you happy for much longer than a generic mouse GPS!
Anyone that complains of handheld GPS sattelite lock troubles can only be using a Garmin!
If I could take a (easy to see in one shot) photo of my
Meridian, squeezed between my PC monitor and tower, bookshelf containing all the other peripherals... printers, routers, cable modem....cables (what a mess!) all the windows have heavy drapes, and only give about a 5degree view of the sky to the south, nothing to the north (lot of walls!) and 2 degrees to the west (between the fence, house next door and the roof) and 1 degree to the east that's totally obscured by the PC tower emitting all kinds of EMF????
6 out of 11 sats... tracking 5 at full noise, 1 is on and off at about 1/3rd maximum!
The external antenna(mounted on the window sill) will hike that up to 8-9 sats at full
bore!
164650
