Cruise Control RA Rodeo
Submitted: Thursday, Mar 09, 2006 at 11:47
BDT
Can anyone identify the speed pulse wire on a 2003 Ra Rodeo 3lt. diesel 4*4 for me, I am fitting an AP150 cruise control
Reply By: Billowaggi - Thursday, Mar 09, 2006 at 18:09
You will get a speed pulse from the speedo sender, you should be able to pick up the wire by its colour code at the back of the speedo and tap in.
Regards Ken.
159548
Follow Up By: BDT - Friday, Mar 17, 2006 at 13:13
Found the wire behind the speedo, black with yellow tracer, fitted the AP150 cruise control, works
BDT
415868
Reply By: Billowaggi - Thursday, Mar 09, 2006 at 18:33
I should also mention the throttle is fly by wire, dont connect the throttle pull to the cable that comes from the accelerator pedal to the inlet manifold ,this is not the throttle! it is a shut off flap to controll engine speed if the electrics go wrong. You need a cruise control that interfaces directly with the wiring on the throttle pedat.
Regards Ken
159552
Follow Up By: Leroy - Friday, Mar 17, 2006 at 13:21
Autron were discontinuing these types of cruises and had a special on them recently. It was on their website.
Leroy
415871
