Wednesday, Mar 08, 2006 at 18:49
Willie,
Definitely not as sticky as the normal and at times wondered whether it would actually have enough stick to stay stuck so to speak. Have used other vinyl stick on signs for advertisers and they do get a grip and have seen paint removed with them - trick there is to use a heat gun and they then come off easily.
This stuff tho came off easily in about five minutes at the motel car wash and was on for about three weeks all up in the west oz sun, middle of summer.
Last summer that is when it was actually hot - not this cool year.
With all these sorts of vinyls, when you remove them you should peel them back on them-selves and not pull at right angles to the flat surface.
If we made an error it was in cutting down the front of the doors, and not just the back, as the leading edges were starting to peel back by the time we had finished this foray into the scrub.
We certainly didn't bother trying to put it on free of creases either, but literally layed it down the side with a slight overlap and presto - banged it on.
The left over bits where the wheels are we used to make patches for those bits we missed.
Not a rembrandt, more of a dog's breakfast to look at - but who cares?
As I mentioned previously, it was pretty shabby when we finished but the paint underneath was pristine after removal requiring no attention at all, apart from a shampoo type wash, thus saving hours with detergents, solvents and polishes.
The cost I can't help you with as son paid for, it but think $50 odd rings a bell for the roll but that was a mates price methinks. It was plain white with a low sheen but felt to be the same weight as normal stick on stuff.
Hope this helps. Its certainly now a part of our shopping lists for future trips.
John G
413937
