Landcruiser Rear Screen Washer
Submitted: Monday, Feb 27, 2006 at 22:06
ThreadID: 31225 Views:3644 Replies:8 FollowUps:1
Just got the new '98 LC RV Diesel and have found that the rear windscreen washer motor operates but is not pumping at the screen. Anyone have some ideas?
Parso
Parso
2012 Toyota Landcruiser 200 Series Sahara.
Reply By: Tim M - Monday, Feb 27, 2006 at 22:17
If the water is spraying elsewear then stick a pin in the nossle and adjust towards the glass
AnswerID: 157396
Follow Up By: Parso - Monday, Feb 27, 2006 at 22:25
No, there is no sign of water anywhere. That's the mystery.
Parso
FollowupID: 411668
Reply By: Dave198 - Monday, Feb 27, 2006 at 22:44
The plastic tube inside the door leading to the jet split on my 60 and I replaced it with a new piece right from the waterbottle.
Check inside the door panel after you activate the washer and see if there is any water inside the doorframe.
Dave
AnswerID: 157404
Reply By: japmel - Monday, Feb 27, 2006 at 23:05
The little jet where the water comes out will be blocked.
Try clearing it with a pin while someone is activating the pump.
japmel
AnswerID: 157408
Reply By: Member - Troll 81 (QLD) - Tuesday, Feb 28, 2006 at 05:30
I had that problem before, the fix was unplugged it at the pump and got the air compressor into it and blew all the gunk out
AnswerID: 157446
Reply By: Shane (QLD) - Tuesday, Feb 28, 2006 at 08:08
On the 60 Series Cruiser there is a non return valve in the plumbing in the rear door. This can block up & no amount of pressure from both ends will shift the blockage. I got rid of mine, but it now takes a little longer to pump from the motor to rear screen.
AnswerID: 157459
Reply By: Member - Davoe (Widgiemooltha) - Tuesday, Feb 28, 2006 at 09:10
I was getting one side of my barn doors wet only. it turned out when one of the doors was closing it was kinking the pipe - could be worth a look although yours is a different setup
AnswerID: 157470
Reply By: Parso - Tuesday, Feb 28, 2006 at 18:47
Thanks guys!
Heaps of ideas on the cure for the problem and I will get to it on the weekend.
My bet it is the non-return valve as the rear wiper/washer circuit has not been operational for some time.
Parso
AnswerID: 157590
Reply By: Geoff M (Newcastle, NSW) - Tuesday, Feb 28, 2006 at 21:36
Fill the bottle?
Geoff,
Landcruiser HDJ78,
AnswerID: 157642
