tips for fitting new suspension???
Submitted: Monday, Feb 27, 2006 at 19:21
simple
just after any little tips and tricks all you wise old folks (and some not so old) might have found to make my job easier when i fit my 2" lift this week?
is there any little hazards i should look out for? it's a GU i'm fitting it to.
thanks y'all have a good night.
Reply By: Footloose - Monday, Feb 27, 2006 at 19:59
Just one. Wear a pair of sunnies when you're underneath the vehicle so that the crud doesn't get in your eyes :))
Also, have a second pair of hands to swing on the wheel if replacing springs.
157353
Reply By: Wayne (NSW) - Monday, Feb 27, 2006 at 20:10
Have a look at post 30584.
It was for a 80 series but the same will apply to a GU
Wayne
157357
Reply By: SteveL - Monday, Feb 27, 2006 at 20:54
When you jack up the vehicle put some blocks of wood under the axle stands to get it as high as you can.This will enable you to lower the
suspension as far as possible and
the springs will almost fall out by themselves.Don't forget to
check the brake lines and diff breathers, you may have to loosen them to give some slack.
157370
Reply By: Member - Tony G (ACT) - Tuesday, Feb 28, 2006 at 08:38
And you will need to extend the rear sway bar.
157463
