Biodiesel question.
Submitted: Tuesday, Feb 07, 2006 at 21:03
1KZ-Mick
Hi Guys,
A friend of
mine has started using Biodiesel in his 3lt Surf, he is on his second tank and is telling me his fuel economy has dropped off by 100km a tank (60lt tank so quite a lot).
Anyone had a similar result?
Reply By: Member - David 0- Tuesday, Feb 07, 2006 at 21:10
Should be better, as it is generally higher octane and better lubricity.
Sometimes causes blockages of filters and such but I've not noticed reduced econmomy
153716
Follow Up By: desert - Tuesday, Feb 07, 2006 at 21:28
Just a technicality, but diesel fuel has a cetane rating, not octane.
407620
Follow Up By: Member - David 0- Tuesday, Feb 07, 2006 at 21:32
Yeah I couldn;t think of the word, and I'm a flamin chemist....brain dead. :-)
407622
Reply By: Vivid Adventures - Tuesday, Feb 07, 2006 at 21:12
If he hasn't replaced his fuel filter, I'd suggest his fuel filter is clogged with the rubbish that has collected in his fuel system over years of dinosaur diesel.
I did replace my fuel filter after the first tank, and the collected deposits are quite evident. Now my economy seems better - but I don't have too much scientific data to go on.
Would strongly recommend he do that if he has not already?
Ciao for now
Andrew.
153718
Follow Up By: 1KZ-Mick - Tuesday, Feb 07, 2006 at 21:33
Thanks, I'll suggest that to him.
Mick.
407623
Reply By: Footloose - Tuesday, Feb 07, 2006 at 22:56
AFAIK this is fairly normal, but it should be more than offset by the cheaper price of biodiesel. Is is cheaper isn't it ? Or is this just another example of having to go into the red to be green ?
153748
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Feb 08, 2006 at 07:20
Its about 10cents a litre cheaper, but as diesel prices climb, watch the biodiesel prices climb,,,, funny about that..
| Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.Member My Profile My Blog Send Message |
407681
Reply By: Snowy 3.0iTD - Wednesday, Feb 08, 2006 at 08:37
Mick
Although Biodiesel has higher lubricity and is better for the environment I recall reading somewhere that it actually has a lower energy value than ordinary diesel. This makes sense to me, as every time I have tried it, I get poorer fuel consumption figures, and noticeably less power under the right foot.
Snowy
153789
Follow Up By: Vivid Adventures - Wednesday, Feb 08, 2006 at 08:40
perhaps you are cleaning out your fuel system with it too?
Get your fuel filter replaced next service!
Ciao for now
Andrew.
407686
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 08, 2006 at 09:01
The cetane rating of the biodiesel depends on the oirginal type of vegetable oil used. Some give a lower and some give a higher cetane rating than petroleum based diesel. But there is an assie standard coming in which will solve the problem.
So doubt it is cetane rating, try your filters.
407694
Follow Up By: Snowy 3.0iTD - Wednesday, Feb 08, 2006 at 09:02
Andrew
I did all the reccommended stuff including replacing fuel filters, have used it on multiple occasions, and I would have thought that a blocked fuel filter would lead to fuel starvation and lack of power, but can not see how it would increase fuel consumption.
Snowy
407696
Reply By: viz - Wednesday, Feb 08, 2006 at 20:49
Wonder how they go with common rail diesels - which use much finer nozzles. Filtration is a much greater issue with this type of injection system...
/viz
153929
