Monday, Jan 23, 2006 at 17:13
G'day Wartgames,
No, I meant that particular brand actually. I currently have the "normal" Nissan viscous fan running off the motor and in front of the air cond (in behind the grille) I have added a small 10" Davies Craig fan, beside the factory-fitted electric air cond fan. I can turn the 10" fan on whenever i like and it's purpose is to aid in the cooling of the radiator in hot conditions. However, I think 10" is not big enough (sounds like something a bloke's wife might say to him, eh??) and was gunna try and fit a bigger, 14" or 16" fan in there. When you look at the specs of the respective outputs (claimed), there is quite a lot more air pushed by a 16" fan than there is by a 10" fan.......And these ones on ebay claim to push a lot more than the Davies Craig equivalent.
The 10" one I have fitted present came with instructions and long bolts that said it was to be mounted through the radiator, like you said. There was NO WAY I was gunna be poking bolts through my radiator!!!!!
Instead, I made up steel brackets to attach the fan to available points on the front.
I would LOVE to remove the standard viscous fan and replace with one or 2 big electric fans, but I'm not convinced about their longevity to do the job solo if you are driving through water crossings etc. Having said that, my davies Craig fan has been dunked a few times and still works okay.
403793
