Headlight fuses on GU Patrol
Submitted: Saturday, Jan 21, 2006 at 11:31
Member - Roachie (SA)
Okay, I'm willing to take a few hits from any smart@rses out there.......
Where the hell is/are the fuse/s for the headlights on the GU Patrol (4.2TD if that matters)???
The first place I looked was on the plastic cover just near the battery/fuel filter. Sure enough there are 2 little boxes on the description panel that say "H/Light L" and "H/Light R"...........
Too easy I thought. I was advised by Frank of Xenonoz to change my fuses from 15amp to 20amp before using the HIDs.
So, I lifted the plastic cover, only to find that half of the slots where fuses are supposed by located are in fact EMPTY!!!, including the 2 spots for the headlights. There are others there which I can understand being vacant (like
seat heaters and headlight washers etc).
So, I checked the fuse panel under the dash, and no headlight fuses there either!!!
Luckily, the HIDs work okay anyway, but strewth, I'd like to know where the fuses are located for 'ron........... ;-)))
